Ethernet Interfaces
| Document revision: | 1.4 (September 10, 2007, 11:48 GMT) |
| Applies to: | V3.0 |
General Information
Summary
MikroTik RouterOS supports various types of Ethernet Interfaces. The complete list of supported Ethernet NICs can be found in the Device Driver List.
Specifications
Packages required: systemLicense required: Level1
Submenu level: /interface ethernet
Standards and Technologies: IEEE 802.3
Hardware usage: Not significant
Additional Resources
Ethernet Interface Configuration
Submenu level: /interface ethernetProperty Description
arp (disabled | enabled | proxy-arp | reply-only; default: enabled) - Address Resolution Protocolauto-negotiation (yes | no; default: yes) - when enabled, the interface "advertises" its maximum capabilities to achieve the best connection possiblecable-setting (default | short | standard; default: default) - changes the cable length setting (only applicable to NS DP83815/6 cards)short - support short cables
standard - same as default
Command Description
blink (name) - blink the port's LEDs for about 10 seconds. Useful if you want to discover, which of the physical Ethernet ports is named as specifiedreset-mac (name) - set the MAC address of the NIC to the factory default settingNotes
When disable-running-check is set to no, the router automatically detects whether the NIC is connected to a device in the network or not. When the remote device is not connected (the leds are not blinking), the route which is set on the specific interface, becomes invalid.
Example
[admin@MikroTik] > interface print
Flags: X - disabled, D - dynamic, R - running
# NAME TYPE MTU
0 X ether1 ether 1500
[admin@MikroTik] > interface enable ether1
# NAME TYPE MTU
0 R ether1 ether 1500
[admin@MikroTik] > interface ethernet
[admin@MikroTik] interface ethernet> print
# NAME MTU MAC-ADDRESS ARP
0 R ether1 1500 00:0C:42:03:00:F2 enabled
[admin@MikroTik] interface ethernet> print detail
0 R name="ether1" mtu=1500 mac-address=00:0C:42:03:00:F2 arp=enabled
disable-running-check=no auto-negotiation=yes full-duplex=yes
cable-settings=default mdix-enable=yes speed=100Mbps
Monitoring the Interface Status
Command name: /interface ethernet monitorProperty Description
auto-negotiation (done | incomplete) - fast link pulses (FLP) to the adjacent link station to negotiate the SPEED and MODE of the link. Both stations choose the maximal speed boh support.incomplete - negotiation failed
no-link - the card is not connected to the network (cable is not plugged in or faulty)
unknown - the connection is not recognized (if the card does not report connection status)
Notes
See the IP Addresses and ARP section of the manual for information how to add IP addresses to the interfaces.
Example
[admin@MikroTik] interface ethernet> monitor ether1,ether2
status: link-ok link-ok
auto-negotiation: done done
rate: 100Mbps 100Mbps
full-duplex: yes yes
default-cable-setting: standard standard
Troubleshooting
Description
Interface monitor shows wrong information
In some very rare cases it is possible that the device driver does not show correct information, but it does not affect the NIC's performance (of course, if your card is not broken)
