Telnet Server and Client
| Document revision: | 2.1 (Mon Jul 19 07:31:04 GMT 2004) |
| Applies to: | V2.9 |
General Information
Summary
MikroTik RouterOS has a build-in Telnet server and client features. These two are used to communicate with other systems over a network.
Specifications
Packages required: systemLicense required: Level1
Submenu level: /system, /ip service
Standards and Technologies: Telnet (RFC 854)
Hardware usage: Not significant
Related Documents
Telnet Server
Submenu level: /ip serviceDescription
Telnet protocol is intended to provide a fairly general, bi-directional, eight-bit byte oriented communications facility. The main goal is to allow a standard method of interfacing terminal devices to each other.
MikroTik RouterOS implements industry standard Telnet server. It uses port 23, which must not be disabled on the router in order to use the feature.
You can enable/disable this service or allow the use of the service to certain IP addresses.
Example
[admin@MikroTik] ip service> print detail Flags: X - disabled, I - invalid 0 name="telnet" port=23 address=0.0.0.0/0 1 name="ftp" port=21 address=0.0.0.0/0 2 name="www" port=80 address=0.0.0.0/0 3 name="hotspot" port=8088 address=0.0.0.0/0 4 name="ssh" port=65 address=0.0.0.0/0 5 X name="hotspot-ssl" port=443 address=0.0.0.0/0 certificate=none [admin@MikroTik] ip service>
Telnet Client
Command name: /system telnet [IP address] [port]Description
MikroTik RouterOS telnet client is used to connect to other hosts in the network via Telnet protocol.
Example
An example of Telnet connection:
[admin@MikroTik] > system telnet 172.16.0.1 Trying 172.16.0.1... Connected to 172.16.0.1. Escape character is '^]'. MikroTik v2.9 Login: admin Password: MMM MMM KKK TTTTTTTTTTT KKK MMMM MMMM KKK TTTTTTTTTTT KKK MMM MMMM MMM III KKK KKK RRRRRR OOOOOO TTT III KKK KKK MMM MM MMM III KKKKK RRR RRR OOO OOO TTT III KKKKK MMM MMM III KKK KKK RRRRRR OOO OOO TTT III KKK KKK MMM MMM III KKK KKK RRR RRR OOOOOO TTT III KKK KKK MikroTik RouterOS 2.9 (c) 1999-2004 http://www.mikrotik.com/ Terminal unknown detected, using single line input mode [admin@MikroTik] >
