Web Proxy
| Document revision: | 1.2 (Tue May 16 14:04:40 GMT 2006) |
| Applies to: | V2.9 |
General Information
Summary
The MikroTik RouterOS implements the following proxy server features:
- Regular HTTP proxy
- Transparent proxy. Can be transparent and regular at the same time
- Access list by source, destination, URL and requested method
- Cache access list (specifies which objects to cache, and which not)
- Direct Access List (specifies which resources should be accessed directly, and which - through another proxy server)
- Logging facility
Quick Setup Guide
To set up a 1 GiB large web cache which will listen on port 8000, do the following:
[admin@MikroTik] ip web-proxy> set enabled=yes port=8000 max-cache-size=1048576
[admin@MikroTik] ip web-proxy> print
enabled: yes
src-address: 0.0.0.0
port: 8000
hostname: proxy
transparent-proxy: no
parent-proxy: 0.0.0.0:0
cache-administrator: webmaster
max-object-size: 4096 KiB
cache-drive: system
max-cache-size: 1048576 KiB
max-ram-cache-size: unlimited
status: rebuilding-cache
reserved-for-cache: 9216 KiB
reserved-for-ram-cache: 2048 KiB
Remember to secure your proxy by preventing unauthorized access to it, otherwise it may be used as an open proxy.
Specifications
Packages required: web-proxyLicense required: Level3
Submenu level: /ip web-proxy
Standards and Technologies: HTTP/1.0, HTTP/1.1, FTP
Hardware usage: uses memory and disk space, if available (see description below)
Related Documents
Description
Web proxy performs Internet object cache function by storing requested Internet objects, i.e., data available via HTTP and FTP protocols on a system positioned closer to the recipient than the site the data is originated from. Here 'closer' means increased path reliability, speed or both. Web browsers can then use the local proxy cache to speed up access and reduce bandwidth consumption.
When setting up Web proxy, make sure it serves only your clients, and is not misused as relay. Please read the security notice in the Access List Section!
Note that it may be useful to have Web proxy running even with no cache when you want to use it as something like HTTP and FTP firewall (for example, denying access to mp3 files) or to redirect requests to external proxy transparently.
Setup
Submenu level: /ip web-proxyProperty Description
cache-administrator (text; default: webmaster) - administrator's e-mail displayed on proxy error pagecache-drive (system | name; default: system) - specifies the target disk drive to be used for storing cached objects. You can use console completion to see the list of available drivesenabled (yes | no; default: no) - specifies whether the web proxy is enabledhostname (text; default: proxy) - hostname (DNS or IP address) of the web proxymax-cache-size (none | unlimited | integer: 0..4294967295; default: none) - specifies the maximal disk cache size, measured in kibibytesmax-object-size (integer; default: 4096) - objects larger than the size specified will not be saved on disk. The value is measured in kibibytes. If you wish to get a high bytes hit ratio, you should probably increase this (one 2 MiB object hit counts for 2048 1KiB hits). If you wish to increase speed more than your want to save bandwidth you should leave this lowmax-ram-cache-size (none | unlimited | integer: 0..4294967295; default: unlimited) - specifies the maximal memory cache size, measured in kibibytesparent-proxy (IP address:port; default: 0.0.0.0:0) - specifies upper-level (parent) proxyport (port{1,10}; default: 3128) - specifies the port(s) the web proxy will be listening onreserved-for-cache (read-only: integer; default: 0) - specifies allocated memory cache size, measured in kibibytesreserved-for-ram-cache (read-only: integer; default: 2048) - specifies allocated memory cache size, measured in kibibytessrc-address (IP address; default: 0.0.0.0) - the web-proxy will use this address connecting to the parent proxy or web site.rebuilding-cache - proxy is enabled and running, existing cache is being verified
running - proxy is enabled and running
stopping - proxy is shutting down (max 10s)
clearing-cache - proxy is stopped, cache files are being removed
creating-cache - proxy is stopped, cache directory structure is being created
dns-missing - proxy is enabled, but not running because of unknown DNS server (you should specify it under /ip dns)
invalid-address - proxy is enabled, but not running because of invalid address (you should change address or port)
invalid-cache-administrator - proxy is enabled, but not running because of invalid cache-administrator's e-mail address
invalid-hostname - proxy is enabled, but not running because of invalid hostname (you should set a valid hostname value)
error-logged - proxy is not running because of unknown error. This error is logged as System-Error. Please, send us this error and some description, how it happened
reserved-for-cache (integer) - maximal cache size, that is accessible to web-proxy
Notes
By default the proxy cache can use as much disk space as there is allocated for it. When the system allocates the space for the proxy cache, 1/7th of the total partition (disk) size is reserved for the system, but not less than 50MB. The rest is left for the proxy cache. The system RAM size is considered as well when allocating the cache size. The cache size is limited so, that there are at least 15MB of RAM per 1GB of cache plus 55MB of RAM is reserved for the system. max-cache-size is also taken in account, so the cache will not occupy more than it is specified in this property. The effective limit is calculated as a minimum of all three limits. Note also that RouterOS supports up to 950MB of memory.
Considering the previous note, you should be aware that you will not be able to enable web proxy, if you have less than 60MB of RAM on your router
Expire time of cache entries can be different for each HTML page (specified in headers). But, if there is no such header, the entry will be considered fresh for not more than 72 hours.
The web proxy listens to all IP addresses that the router has in its IP address list.
Example
To enable the proxy on port 8080:
[admin@MikroTik] ip web-proxy> set enabled=yes port=8080
enabled: yes
port: 8080
hostname: proxy
cache-drive: system
max-cache-size: none
status: running
reserved-for-cache: 0 KiB
Access List
Submenu level: /ip web-proxy accessDescription
Access list is configured in the same way as MikroTik RouterOS firewall rules. Rules are processed from the top to the bottom. First matching rule specifies decision of what to do with this connection. There is a total of 6 classifiers that specify matching constraints. If none of these classifiers is specified, the particular rule will match every connection.
If connection is matched by a rule, action property of this rule specifies whether connection will be allowed or not. If the particular connection does not match any rule, it will be allowed.
By default, there is one rule, which prevents connect requests to ports other then 443 and 563.
action (allow | deny; default: allow) - specifies whether to pass or deny matched packetsdst-address (IP address/netmask) - destination address of the IP packetdst-port (port{1,10}) - a list or range of ports the packet is destined tolocal-port (port) - specifies the port of the web proxy via which the packet was received. This value should match one of the ports web proxy is listening on.method (any | connect | delete | get | head | options | post | put | trace) - HTTP method used in the request (see HTTP Methods section at the end of this document)src-address (IP address/netmask) - source address of the IP packeturl (wildcard) - the URL of the HTTP requestNotes
There is one rule by default, that disallows connect method connections to ports other than 443 (https) and 563 (snews). connect method is a security hole that allows connections (transparent tunneling) to any computer using any protocol. It is used mostly by spammers, as they found it very convenient to use others' mail (SMTP) servers as anonymous mail relay to send spam over the Internet.
It is strongly recommended to deny all IP addresses except those behind the router as the proxy still may be used to access your internal-use-only (intranet) web servers. Also, consult examples in Firewall Manual on how to protect your router.
Wildcard property url matches a complete string (i.e., they will not match "example.com" if they are set to "example"). Available wildcards are '*' (match any number of any characters) and '?' (match any one character). Regular expressions are also accepted here, but if the property should be treated as a regular expression, it should start with a colon (':').
Small hits in using regular expressions:
- \\ symbol sequence is used to enter \ character in console
- \. pattern means . only (in regular expressions single dot in pattern means any symbol)
- to show that no symbols are allowed before the given pattern, we use ^ symbol at the beginning of the pattern
- to specify that no symbols are allowed after the given pattern, we use $ symbol at the end of the pattern
- to enter [ or ] symbols, you should escape them with backslash \.
Example
The default rule:
[admin@MikroTik] ip web-proxy access> print
0 ;;; allow CONNECT only to SSL ports 443 [https] and 563 [snews]
dst-port=!443,563 method=connect action=deny
To disallow download of .MP3 and .MPG files and FTP connections other than from the 10.0.0.1 server:
[admin@MikroTik] ip web-proxy access> add url=":\\.mp\[3g\]$" action=deny
[admin@MikroTik] ip web-proxy access> add src-address=10.0.0.1/32 action=allow
[admin@MikroTik] ip web-proxy access> add url="ftp://*" action=deny
1 url=":\.mp[3g]$" action=deny
2 src-address=10.0.0.1/32 action=allow
3 url="ftp://*" action=deny
Direct Access List
Submenu level: /ip web-proxy directDescription
If parent-proxy property is specified, it is possible to tell the proxy server whether to try to pass the request to the parent proxy or to resolve it connecting to the requested server directly. Direct Access List is managed just like Proxy Access List described in the previous chapter except the action argument.
action (allow | deny; default: allow) - specifies the action to perform on matched packetsdeny - resolve matched requests through the parent proxy. If no one is specified this has the same effect as allow
Notes
Unlike the access list, the direct proxy access list has default action equal to deny. It takes place when no rules are specified or a particular request did not match any rule.
Cache Management
Submenu level: /ip web-proxy cacheDescription
Cache access list specifies, which requests (domains, servers, pages) have to be cached locally by web proxy, and which not. This list is implemented exactly the same way as web proxy access list. Default action is to cache object (if no matching rule is found).
action (allow | deny; default: allow) - specifies the action to perform on matched packetsdeny - do not cache objects from matched request
Complementary Tools
Description
Web proxy has additional commands to handle non-system drive used for caching purposes and to recover the proxy from severe file system errors.
Command Description
check-drive - checks non-system cache drive for errorsclear-cache - deletes existing cache and creates new cache directoriesformat-drive - formats non-system cache drive and prepairs it for holding the cacheTransparent Mode
Description
Transparent proxy feature performs request caching invisibly to the end-user. This way the user does not notice that his connection is being processed by the proxy and therefore does not need to perform any additional configuration of the software he is using.
This feature may as well be combined with bridge to simplify deployment of web proxy in the existing infrastructure.
To enable the transparent mode, place a firewall rule in destination NAT, specifying which connections, id est traffic coming to which ports should be redirected to the proxy.
Notes
Only HTTP traffic is supported in transparent mode of the web proxy. HTTPS and FTP protocols are not going to work this way.
Example
To configure the router to transparently redirect all connections coming from ether1 interface to port 80 to the web proxy listening on port 8080, then add the following destination NAT rule:
[admin@MikroTik] > /ip firewall nat add in-interface=ether1 dst-port=80 \
\... protocol=tcp action=redirect to-ports=8080 chain=dstnat
[admin@MikroTik] > /ip firewall nat print
0 chain=dstnat protocol=tcp in-interface=ether1 dst-port=80 action=redirect
to-ports=8080
[admin@MikroTik] >
NotesBe aware, that you will not be able to access the router's web page after addition of the rule above unless you will change the port for the www service under /ip service submenu to a different value or explicitly exclude router's IP address from those to be matched, like:
/ip firewall nat add in-interface=ether1 dst-port=80 \ \... protocol=tcp action=redirect to-ports=8080 chain=dstnat dst-address=!1.1.1.1/32
It is assumed that the router's address is 1.1.1.1/32.
HTTP Methods
Description
OPTIONSThis method is a request of information about the communication options available on the chain between the client and the server identified by the Request-URI. The method allows the client to determine the options and (or) the requirements associated with a resource without initiating any resource retrieval
GETThis method retrieves whatever information identified by the Request-URI. If the Request-URI refers to a data processing process than the response to the GET method should contain data produced by the process, not the source code of the process procedure(-s), unless the source is the result of the process.
The GET method can become a conditional GET if the request message includes an If-Modified-Since, If-Unmodified-Since, If-Match, If-None-Match, or If-Range header field. The conditional GET method is used to reduce the network traffic specifying that the transfer of the entity should occur only under circumstances described by conditional header field(-s).
The GET method can become a partial GET if the request message includes a Range header field. The partial GET method intends to reduce unnecessary network usage by requesting only parts of entities without transferring data already held by client.
The response to a GET request is cacheable if and only if it meets the requirements for HTTP caching.
HEADThis method shares all features of GET method except that the server must not return a message-body in the response. This retrieves the metainformation of the entity implied by the request which leads to a wide usage of it for testing hypertext links for validity, accessibility, and recent modification.
The response to a HEAD request may be cacheable in the way that the information contained in the response may be used to update previously cached entity identified by that Request-URI.
POSTThis method requests that the origin server accept the entity enclosed in the request as a new subordinate of the resource identified by the Request-URI.
The actual action performed by the POST method is determined by the origin server and usually is Request-URI dependent.
Responses to POST method are not cacheable, unless the response includes appropriate Cache-Control or Expires header fields.
PUTThis method requests that the enclosed entity be stored under the supplied Request-URI. If another entity exists under specified Request-URI, the enclosed entity should be considered as updated (newer) version of that residing on the origin server. If the Request-URI is not pointing to an existing resource, the origin server should create a resource with that URI.
If the request passes through a cache and the Request-URI identifies one or more currently cached entities, those entries should be treated as stale. Responses to this method are not cacheable.
TRACEThis method invokes a remote, application-layer loop-back of the request message. The final recipient of the request should reflect the message received back to the client as the entity-body of a 200 (OK) response. The final recipient is either the origin server or the first proxy or gateway to receive a Max-Forwards value of 0 in the request. A TRACE request must not include an entity.
Responses to this method MUST NOT be cached.
