IP Security
Document revision:3.4 (Tue Nov 22 14:19:15 GMT 2005)
Applies to: V2.9
General Information
Specifications
Packages required: security
License required: Level1
Submenu level: /ip ipsec
Standards and Technologies: IPsec
Hardware usage: consumes a lot of CPU time (Intel Pentium MMX or AMD K6 suggested as a minimal configuration)
Related Documents
Description
IPsec (IP Security) supports secure (encrypted) communications over IP networks.
Encryption
After packet is src-natted, but before putting it into interface queue, IPsec policy database is consulted to find out if packet should be encrypted. Security Policy Database (SPD) is a list of rules that have two parts:
Each SPD rule can be associated with several Security Associations (SA) that determine packet encryption parameters (key, algorithm, SPI).
Note that packet can only be encrypted if there is usable SA for policy rule. By setting SPD rule security "level" user can control what happens when there is no valid SA for policy rule:
Decryption
When encrypted packet is received for local host (after dst-nat and input filter), the appropriate SA is looked up to decrypt it (using packet source, destination, security protocol and SPI value). If no SA is found, the packet is dropped. If SA is found, packet is decrypted. Then decrypted packet's fields are compared to policy rule that SA is linked to. If the packet does not match the policy rule it is dropped. If the packet is decrypted fine (or authenticated fine) it is "received once more" - it goes through dst-nat and routing (which finds out what to do - either forward or deliver locally) again.
Note that before forward and input firewall chains, a packet that was not decrypted on local host is compared with SPD reversing its matching rules. If SPD requires encryption (there is valid SA associated with matching SPD rule), the packet is dropped. This is called incoming policy check.
Internet Key Exchange
The Internet Key Exchange (IKE) is a protocol that provides authenticated keying material for Internet Security Association and Key Management Protocol (ISAKMP) framework. There are other key exchange schemes that work with ISAKMP, but IKE is the most widely used one. Together they provide means for authentication of hosts and automatic management of security associations (SA).
Most of the time IKE daemon is doing nothing. There are two possible situations when it is activated:
In both cases, peers establish connection and execute 2 phases:
There are two lifetime values - soft and hard. When SA reaches it's soft lifetime treshold, the IKE daemon receives a notice and starts another phase 2 exchange to replace this SA with fresh one. If SA reaches hard lifetime, it is discarded.
IKE can optionally provide a Perfect Forward Secrecy (PFS), whish is a property of key exchanges, that, in turn, means for IKE that compromising the long term phase 1 key will not allow to easily gain access to all IPsec data that is protected by SAs established through this phase 1. It means an additional keying material is generated for each phase 2.
Generation of keying material is computationally very expensive. Exempli gratia, the use of modp8192 group can take several seconds even on very fast computer. It usually takes place once per phase 1 exchange, which happens only once between any host pair and then is kept for long time. PFS adds this expensive operation also to each phase 2 exchange.
Diffie-Hellman MODP Groups
Diffie-Hellman (DH) key exchange protocol allows two parties without any initial shared secret to create one securely. The following Modular Exponential (MODP) Diffie-Hellman (also known as "Oakley") Groups are supported:
Diffie-Hellman Group Modulus Reference
Group 1 768 bits RFC2409
Group 2 1024 bits RFC2409
Group 5 1536 bits RFC3526
IKE Traffic
To avoid problems with IKE packets hit some SPD rule and require to encrypt it with not yet established SA (that this packet perhaps is trying to establish), locally originated packets with UDP source port 500 are not processed with SPD. The same way packets with UDP destination port 500 that are to be delivered locally are not processed in incoming policy check.
Setup Procedure
To get IPsec to work with automatic keying using IKE-ISAKMP you will have to configure policy, peer and proposal (optional) entries.
For manual keying you will have to configure policy and manual-sa entries.
Policy Settings
Submenu level: /ip ipsec policy
Description
Policy table is needed to determine whether encryption should be applied to a packet.
Property Description
action (accept | drop | encrypt; default: accept) - specifies what action to undertake with a packet that matches the policy
accept - pass the packet
drop - drop the packet
encrypt - apply transformations specified in this policy and it's SA
decrypted (integer) - how many incoming packets were decrypted by the policy
dont-fragment (clear | inherit | set; default: clear) - The state of the don't fragment IP header field
clear - clear (unset) the fields, so that packets previously marked as don't fragment got fragmented
inherit - do not change the field
set - set the field, so that each packet matching the rule will not be fragmented
dst-address (IP address/netmask:port; default: 0.0.0.0/32:any) - destination IP address
encrypted (integer) - how many outgoing packets were encrypted by the policy
in-accepted (integer) - how many incoming packets were passed through by the policy without an attempt to decrypt
in-dropped (integer) - how many incoming packets were dropped by the policy without an attempt to decrypt
ipsec-protocols (multiple choice: ah | esp; default: esp) - specifies what combination of Authentication Header and Encapsulating Security Payload protocols you want to apply to matched traffic. AH is applied after ESP, and in case of tunnel mode ESP will be applied in tunnel mode and AH - in transport mode
level (acquire | require | use; default: require) - specifies what to do if some of the SAs for this policy cannot be found:
use - skip this transform, do not drop packet and do not acquire SA from IKE daemon
acquire - skip this transform, but acquire SA for it from IKE daemon
require - drop packet but acquire SA
manual-sa (name; default: none) - name of manual-sa template that will be used to create SAs for this policy
none - no manual keys are set
not-decrypted (integer) - how many incoming packets the policy attempted to decrypt. but discarded for any reason
not-encrypted (integer) - how many outgoing packets the policy attempted to encrypt. but discarded for any reason
out-accepted (integer) - how many outgoing packets were passed through by the policy without an attempt to encrypt
out-dropped (integer) - how many outgoing packets were dropped by the policy without an attempt to encrypt
ph2-state (read-only: expired | no-phase2 | established) - indication of the progress of key establishing
expired - there are some leftovers from previous phase2. In general it is similar to no-phase2
no-phase2 - no keys are estabilished at the moment
estabilished - Appropriate SAs are in place and everything should be working fine
proposal (name; default: default) - name of proposal information that will be sent by IKE daemon to establish SAs for this policy
protocol (name | integer; default: all) - protocol name or number
sa-dst-address (IP address; default: 0.0.0.0) - SA destination IP address
sa-src-address (IP address; default: 0.0.0.0) - SA source IP address
src-address (IP address/netmask:port; default: 0.0.0.0/32:any) - source IP address
tunnel (yes | no; default: no) - specifies whether to use tunnel mode
Notes
All packets are IPIP encapsulated in tunnel mode, and their new IP header src-address and dst-address are set to sa-src-address and sa-dst-address values of this policy. If you do not use tunnel mode (id est you use transport mode), then only packets whose source and destination addresses are the same as sa-src-address and sa-dst-address can be processed by this policy. Transport mode can only work with packets that originate at and are destined for IPsec peers (hosts that established security associations). To encrypt traffic between networks (or a network and a host) you have to use tunnel mode.
It is good to have dont-fragment cleared because encrypted packets are always bigger than original and thus they may need fragmentation.
If you are using IKE to establish SAs automatically, then policies on both routers must exactly match each other, id est src-address=1.2.3.0/27 on one router and dst-address=1.2.3.0/28 on another would not work. Source address values on one router MUST be equal to destination address values on the other one, and vice versa.
Example
To add a policy to encrypt all the traffic between two hosts (10.0.0.147 and 10.0.0.148), we need do the following:
[admin@WiFi] ip ipsec policy> add sa-src-address=10.0.0.147 \
\... sa-dst-address=10.0.0.148 action=encrypt
[admin@WiFi] ip ipsec policy> print
Flags: X - disabled, D - dynamic, I - invalid
 0   src-address=10.0.0.147/32:any dst-address=10.0.0.148/32:any protocol=all
     action=encrypt level=require ipsec-protocols=esp tunnel=no
     sa-src-address=10.0.0.147 sa-dst-address=10.0.0.148 proposal=default
     manual-sa=none dont-fragment=clear
to view the policy statistics, do the following:
[admin@WiFi] ip ipsec policy> print stats
      protocol=all ph2-state=no-phase2 in-accepted=0 in-dropped=0
      out-accepted=0 out-dropped=0 encrypted=0 not-encrypted=0 decrypted=0
      not-decrypted=0
Peers
Submenu level: /ip ipsec peer
Description
Peer configuration settings are used to establish connections between IKE daemons (phase 1 configuration). This connection then will be used to negotiate keys and algorithms for SAs.
address (IP address/netmask:port; default: 0.0.0.0/32:500) - address prefix. If remote peer's address matches this prefix, then this peer configuration is used while authenticating and establishing phase 1. If several peer's addresses matches several configuration entries, the most specific one (i.e. the one with largest netmask) will be used
dh-group (multiple choice: modp768 | modp1024 | modp1536; default: esp) - Diffie-Hellman MODP group (cipher strength)
enc-algorithm (multiple choice: des | 3des | aes-128 | aes-192 | aes-256; default: 3des) - encryption algorithm. Algorithms are named in strength increasing order
exchange-mode (multiple choice: main | aggressive | base; default: main) - different ISAKMP phase 1 exchange modes according to RFC 2408.DO not use other modes then main unless you know what you are doing
generate-policy (yes | no; default: no) - allow this peer to establish SA for non-existing policies. Such policies are created dynamically for the lifetime of SA. This way it is possible, for example, to create IPsec secured L2TP tunnels, or any other setup where remote peer's IP address is not known at configuration time
hash-algorithm (multiple choice: md5 | sha; default: md5) - hashing algorithm. SHA (Secure Hash Algorithm) is stronger, but slower
lifebytes (integer; default: 0) - phase 1 lifetime: specifies how much bytes can be transferred before SA is discarded
0 - SA expiration will not be due to byte count excess
lifetime (time; default: 1d) - phase 1 lifetime: specifies how long the SA will be valid; SA will be discarded after this time
proposal-check (multiple choice: claim | exact | obey | strict; default: strict) - phase 2 lifetime check logic:
claim - take shortest of proposed and configured lifetimes and notify initiator about it
exact - require lifetimes to be the same
obey - accept whatever is sent by an initiator
strict - If proposed lifetime IS longer than default then reject proposal otherwise accept proposed lifetime
secret (text; default: "") - secret string. If it starts with '0x', it is parsed as a hexadecimal value
send-initial-contact (yes | no; default: yes) - specifies whether to send initial IKE information or wait for remote side
Notes
AES (Advanced Encryption Standard) encryption algorithms are much faster than DES, so it is recommended to use this algorithm class whenever possible. But, AES's speed is also its drawback as it potentially can be cracked faster, so use AES-256 when you need security or AES-128 when speed is also important.
Both peers MUST have the same encryption and authentication algorithms, DH group and exchange mode. Some legacy hardware may support only DES and MD5.
You should set generate-policy flag to yes only for trusted peers, because there is no verification done for the established policy. To protect yourself against possible unwanted events, add policies with action=accept for all networks you don't want to be encrypted at the top of policy list. Since dynamic policies are added at the bottom of the list, they will not be able to override your configuration.
Example
To define new peer configuration for 10.0.0.147 peer with secret=gwejimezyfopmekun:
[admin@WiFi] ip ipsec peer>add address=10.0.0.147/32 \
\... secret=gwejimezyfopmekun
[admin@WiFi] ip ipsec peer> print
Flags: X - disabled
  0   address=10.0.0.147/32:500 secret="gwejimezyfopmekun" generate-policy=no
      exchange-mode=main send-initial-contact=yes proposal-check=obey
      hash-algorithm=md5 enc-algorithm=3des dh-group=modp1024 lifetime=1d
      lifebytes=0
Remote Peer Statistics
Submenu level: /ip ipsec remote-peers
Description
This submenu provides you with various statistics about remote peers that currently have established phase 1 connections with this router. Note that if peer doesn't show up here, it doesn't mean that no IPsec traffic is being exchanged with it. For example, manually configured SAs will not show up here.
estabilished (read-only: text) - shows date and time when phase 1 was established with the peer
local-address (read-only: IP address) - local ISAKMP SA address
ph2-active (read-only: integer) - how many phase 2 negotiations with this peer are currently taking place
ph2-total (read-only: integer) - how many phase 2 negotiations with this peer took place
remote-address (read-only: IP address) - peer's IP address
side (multiple choice, read-only: initiator | responder) - shows which side initiated the connection
initiator - phase 1 negotiation was started by this router
responder - phase 1 negotiation was started by peer
state (read-only: text) - state of phase 1 negotiation with the peer
estabilished - normal working state
Example
To see currently estabilished SAs:
[admin@WiFi] ip ipsec> remote-peers print
  0 local-address=10.0.0.148 remote-address=10.0.0.147 state=established
    side=initiator established=jan/25/2003 03:34:45 ph2-active=0 ph2-total=1
Installed SAs
Submenu level: /ip ipsec installed-sa
Description
This facility provides information about installed security associations including the keys
add-lifetime (read-only: time) - soft/hard expiration time counted from installation of SA
auth-algorithm (multiple choice, read-only: none | md5 | sha1) - authentication algorithm used in SA
auth-key (read-only: text) - authentication key presented in form of hex string
current-addtime (read-only: text) - time when this SA was installed
current-bytes (read-only: integer) - amount of data processed by this SA's crypto algorithms
current-usetime (read-only: text) - time when this SA was first used
direction (multiple choice, read-only: in | out) - SA direction
dst-address (read-only: IP address) - destination address of SA taken from respective policy
enc-algorithm (multiple choice, read-only: none | des | 3des | aes) - encryption algorithm used in SA
enc-key (read-only: text) - encryption key presented in form of hex string (not applicable to AH SAs)
lifebytes (read-only: integer) - soft/hard expiration threshold for amount of processed data
replay (read-only: integer) - size of replay window presented in bytes. This window protects the receiver against replay attacks by rejecting old or duplicate packets.
spi (read-only: integer) - SPI value of SA, represented in hexadecimal form
src-address (read-only: IP address) - source address of SA taken from respective policy
state (multiple choice, read-only: larval | mature | dying | dead) - SA living phase
use-lifetime (read-only: time) - soft/hard expiration time counted from the first use of SA
Example
Sample printout looks as follows:
[admin@WiFi] ip ipsec> installed-sa print
Flags: A - AH, E - ESP, P - pfs, M - manual
  0 E   spi=E727605 direction=in src-address=10.0.0.148
        dst-address=10.0.0.147 auth-algorithm=sha1 enc-algorithm=3des
        replay=4 state=mature
        auth-key="ecc5f4aee1b297739ec88e324d7cfb8594aa6c35"
        enc-key="d6943b8ea582582e449bde085c9471ab0b209783c9eb4bbd"
        add-lifetime=24m/30m use-lifetime=0s/0s lifebytes=0/0
        current-addtime=jan/28/2003 20:55:12
        current-usetime=jan/28/2003 20:55:23 current-bytes=128
  1 E   spi=E15CEE06 direction=out src-address=10.0.0.147
        dst-address=10.0.0.148 auth-algorithm=sha1 enc-algorithm=3des
        auth-key="8ac9dc7ecebfed9cd1030ae3b07b32e8e5cb98af"
        enc-key="8a8073a7afd0f74518c10438a0023e64cc660ed69845ca3c"
        current-usetime=jan/28/2003 20:55:12 current-bytes=512
Flushing Installed SA Table
Command name: /ip ipsec installed-sa flush
Description
Sometimes after incorrect/incomplete negotiations took place, it is required to flush manually the installed SA table so that SA could be renegotiated. This option is provided by the flush command.
sa-type (multiple choice: ah | all | esp; default: all) - specifies SA types to flush
ah - delete AH protocol SAs only
esp - delete ESP protocol SAs only
all - delete both ESP and AH protocols SAs
Example
To flush all the SAs installed:
[admin@MikroTik] ip ipsec installed-sa> flush
[admin@MikroTik] ip ipsec installed-sa> print
Counters
Submenu level: /ip ipsec counters
in-accept (read-only: integer) - shows how many incoming packets were matched by accept policy
in-accept-isakmp (read-only: integer) - shows how many incoming UDP packets on port 500 were let through without matching a policy
in-decrypted (read-only: integer) - shows how many incoming packets were successfully decrypted
in-drop (read-only: integer) - shows how many incoming packets were matched by drop policy (or encrypt policy with level=require that does not have all necessary SAs)
in-drop-encrypted-expected (read-only: integer) - shows how many incoming packets were matched by encrypt policy and dropped because they were not encrypted
out-accept (read-only: integer) - shows how many outgoing packets were matched by accept policy (including the default "accept all" case)
out-accept-isakmp (read-only: integer) - shows how many locally originated UDP packets on source port 500 (which is how ISAKMP packets look) were let through without policy matching
out-drop (read-only: integer) - shows how many outgoing packets were matched by drop policy (or encrypt policy with level=require that does not have all necessary SAs)
out-encrypt (read-only: integer) - shows how many outgoing packets were encrypted successfully
Example
To view current statistics:
[admin@WiFi] ip ipsec> counters print
                    out-accept: 6
             out-accept-isakmp: 0
                      out-drop: 0
                   out-encrypt: 7
                     in-accept: 12
              in-accept-isakmp: 0
                       in-drop: 0
                  in-decrypted: 7
    in-drop-encrypted-expected: 0
Application Examples
MikroTik Router to MikroTik Router
MT to MT
IPsec Between two Masquerading MikroTik Routers
MT to MT with Masquerading
  1. Add accept and masquerading rules in SRC-NAT
    • for Router1
      [admin@Router1] > ip firewall nat add chain=srcnat src-address=10.1.0.0/24 \
      \... dst-address=10.2.0.0/24
      [admin@Router1] > ip firewall nat add chain=srcnat out-interface=public \
      \... action=masquerade
    • for Router2
      [admin@Router2] > ip firewall nat chain=srcnat add src-address=10.2.0.0/24 \
      \... dst-address=10.1.0.0/24
      [admin@Router2] > ip firewall nat chain=srcnat add out-interface=public \
  2. configure IPsec
    • for Router1
      [admin@Router1] > ip ipsec policy add src-address=10.1.0.0/24 \
      \... dst-address=10.2.0.0/24 action=encrypt tunnel=yes \
      \... sa-src-address=1.0.0.1 sa-dst-address=1.0.0.2
      [admin@Router1] > ip ipsec peer add address=1.0.0.2 \
      \... exchange-mode=aggressive secret="gvejimezyfopmekun"
    • for Router2
      [admin@Router2] > ip ipsec policy add src-address=10.2.0.0/24 \
      \... dst-address=10.1.0.0/24 action=encrypt tunnel=yes \
      \... sa-src-address=1.0.0.2 sa-dst-address=1.0.0.1
      [admin@Router2] > ip ipsec peer add address=1.0.0.1 \
MikroTik router to CISCO Router
MT to CISCO
We will configure IPsec in tunnel mode in order to protect traffic between attached subnets.
  1. Add peer (with phase1 configuration parameters), DES and SHA1 will be used to protect IKE traffic
    • for MikroTik router
      [admin@MikroTik] > ip ipsec peer add address=10.0.1.2 \
      \... secret="gvejimezyfopmekun" enc-algorithm=des
    • for CISCO router
      ! Configure ISAKMP policy (phase1 config, must match configuration
      ! of "/ip ipsec peer" on RouterOS). Note that DES is default
      ! encryption algorithm on Cisco. SHA1 is default authentication
      ! algorithm
      crypto isakmp policy 9
        encryption des
        authentication pre-share
        group 2
        hash md5
        exit
      ! Add preshared key to be used when talking to RouterOS
      crypto isakmp key gvejimezyfopmekun address 10.0.1.1 255.255.255.255
  2. Set encryption proposal (phase2 proposal - settings that will be used to encrypt actual data) to use DES to encrypt data
      [admin@MikroTik] > ip ipsec proposal set default enc-algorithms=des
    • for CISCO router
      ! Create IPsec transform set - transformations that should be applied to
      ! traffic - ESP encryption with DES and ESP authentication with SHA1
      ! This must match "/ip ipsec proposal"
      crypto ipsec transform-set myset esp-des esp-sha-hmac
        mode tunnel
        exit
  3. Add policy rule that matches traffic between subnets and requires encryption with ESP in tunnel mode
      [admin@MikroTik] > ip ipsec policy add \
      \... src-address=10.0.0.0/24 dst-address=10.0.2.0/24 action=encrypt \
      \... tunnel=yes sa-src=10.0.1.1 sa-dst=10.0.1.2
    • for CISCO router
      ! Create access list that matches traffic that should be encrypted
      access-list 101 permit ip 10.0.2.0 0.0.0.255 10.0.0.0 0.0.0.255
      ! Create crypto map that will use transform set "myset", use peer 10.0.1.1
      ! to establish SAs and encapsulate traffic and use access-list 101 to
      ! match traffic that should be encrypted
      crypto map mymap 10 ipsec-isakmp
        set peer 10.0.1.1
        set transform-set myset
        set pfs group2
        match address 101
        exit
      ! And finally apply crypto map to serial interface:
      interface Serial 0
        crypto map mymap
        exit
  4. Testing the IPsec tunnel
    • on MikroTik router we can see installed SAs
        0 E   spi=9437482 direction=out src-address=10.0.1.1
              dst-address=10.0.1.2 auth-algorithm=sha1 enc-algorithm=des
              auth-key="9cf2123b8b5add950e3e67b9eac79421d406aa09"
              enc-key="ffe7ec65b7a385c3" add-lifetime=24m/30m use-lifetime=0s/0s
              lifebytes=0/0 current-addtime=jul/12/2002 16:13:21
              current-usetime=jul/12/2002 16:13:21 current-bytes=71896
        1 E   spi=319317260 direction=in src-address=10.0.1.2
              dst-address=10.0.1.1 auth-algorithm=sha1 enc-algorithm=des
              auth-key="7575f5624914dd312839694db2622a318030bc3b"
              enc-key="633593f809c9d6af" add-lifetime=24m/30m use-lifetime=0s/0s
              current-usetime=jul/12/2002 16:13:21 current-bytes=0
    • on CISCO router
      cisco# show interface Serial 0
      interface: Serial1
          Crypto map tag: mymap, local addr. 10.0.1.2
         local  ident (addr/mask/prot/port): (10.0.2.0/255.255.255.0/0/0)
         remote ident (addr/mask/prot/port): (10.0.0.0/255.255.255.0/0/0)
         current_peer: 10.0.1.1
           PERMIT, flags={origin_is_acl,}
          #pkts encaps: 1810, #pkts encrypt: 1810, #pkts digest 1810
          #pkts decaps: 1861, #pkts decrypt: 1861, #pkts verify 1861
          #pkts compressed: 0, #pkts decompressed: 0
          #pkts not compressed: 0, #pkts compr. failed: 0, #pkts decompress failed: 0
          #send errors 0, #recv errors 0
           local crypto endpt.: 10.0.1.2, remote crypto endpt.: 10.0.1.1
           path mtu 1500, media mtu 1500
           current outbound spi: 1308650C
           inbound esp sas:
            spi: 0x90012A(9437482)
              transform: esp-des esp-sha-hmac ,
              in use settings ={Tunnel, }
              slot: 0, conn id: 2000, flow_id: 1, crypto map: mymap
              sa timing: remaining key lifetime (k/sec): (4607891/1034)
              IV size: 8 bytes
              replay detection support: Y
           inbound ah sas:
           inbound pcp sas:
           outbound esp sas:
            spi: 0x1308650C(319317260)
              slot: 0, conn id: 2001, flow_id: 2, crypto map: mymap
              sa timing: remaining key lifetime (k/sec): (4607893/1034)
              IV size: 8 bytes
           outbound ah sas:
           outbound pcp sas:
MikroTik Router and Linux FreeS/WAN
In the test scenario we have 2 private networks: 10.0.0.0/24 connected to the MT and 192.168.87.0/24 connected to Linux. MT and Linux are connected together over the "public" network 192.168.0.0/24:
MT to FreeS/WAN
