SOCKS Proxy Server
| Document revision: | 1.4 (January 14, 2008, 11:23 GMT) |
| Applies to: | V3.0 |
General Information
Summary
This manual discusses the SOCKS proxy server which is implemented in RouterOS. MikroTik RouterOS supports SOCKS version 4.
Specifications
Packages required: systemLicense required: Level1
Submenu level: /ip socks
Standards and Technologies: SOCKS version 4
Hardware usage: Not significant
Description
SOCKS is a proxy server that allows TCP based application data to relay across the firewall, even if the firewall would block the packets. The SOCKS protocol is independent from application protocols, so it can be used for many services, e.g, WWW, FTP, TELNET, and others.
At first, an application client connects to the SOCKS proxy server, then the proxy server looks in its access list to see whether the client is permited to access the remote application resource or not, if it is permitted, the proxy server relies the packet to the application server and creates a connection between the application server and client.
Notes
Remember to configure your application client to use SOCKS version 4.
You should secure the SOCKS proxy using its access list and/or firewall to disallow access from outisde. Failing to secure the proxy server may introduce security issues to your network, and may provide a way for spammers to send junk mail through the router.
Additional Resources
SOCKS Configuration
Description
In this section you will learn how to enable the SOCKS proxy server and do its configuration.
Property Description
connection-idle-timeout (time; default: 2m) - time after which idle connections are terminatedenabled (yes | no; default: no) - whether to enable or no the SOCKS proxymax-connections (integer: 1..500; default: 200) - maxumum number of simultaneous connectionsport (integer: 1..65535; default: 1080) - TCP port on which the SOCKS server listens for connectionsExample
To enable SOCKS:
[admin@MikroTik] ip socks> set enabled=yes
[admin@MikroTik] ip socks> print
enabled: yes
port: 1080
connection-idle-timeout: 2m
max-connections: 200
Access List
Submenu level: /ip socks accessDescription
In the SOCKS access list you can add rules which will control access to SOCKS server. This list is similar to firewall lists.
action (allow | deny; default: allow) - action to be performed for this ruledeny - deny access for packets, matching this rule
Active Connections
Submenu level: /ip socks connectionsDescription
The Active Connection list shows all established TCP connections, which are maintained through the SOCKS proxy server.
dst-address (read-only: IP address) - destination (application server) IP addressrx (read-only: integer) - bytes receivedsrc-address (read-only: IP address) - source (application client) IP addresstx (read-only: integer) - bytes senttype (read-only: in | out | unknown) - connection typeout - outgoing connection
unknown - connection has just been initiated
Example
To see current TCP connections:
[admin@MikroTik] ip socks connections> print # SRC-ADDRESS DST-ADDRESS TX RX 0 192.168.0.2:3242 159.148.147.196:80 4847 2880 1 192.168.0.2:3243 159.148.147.196:80 3408 2127 2 192.168.0.2:3246 159.148.95.16:80 10172 25207 3 192.168.0.2:3248 194.8.18.26:80 474 1629 4 192.168.0.2:3249 159.148.95.16:80 6477 18695 5 192.168.0.2:3250 159.148.95.16:80 4137 27568 6 192.168.0.2:3251 159.148.95.16:80 1712 14296 7 192.168.0.2:3258 80.91.34.241:80 314 208 8 192.168.0.2:3259 80.91.34.241:80 934 524 9 192.168.0.2:3260 80.91.34.241:80 930 524 10 192.168.0.2:3261 80.91.34.241:80 312 158 11 192.168.0.2:3262 80.91.34.241:80 312 158 [admin@MikroTik] ip socks connections>
Application Examples
FTP service through SOCKS server
Let us consider that we have a network 192.168.0.0/24 which is masqueraded, using a router with a public IP 10.1.0.104/24 and a private IP 192.168.0.1/24. Somewhere in the network is an FTP server with IP address 10.5.8.8. We want to allow access to this FTP server for a client in our local network with IP address 192.168.0.2/24.
We have already masqueraded our local network:
[admin@MikroTik] ip firewall nat> print Flags: X - disabled, I - invalid, D - dynamic 0 chain=srcnat action=masquerade src-address=192.168.0.0/24 [admin@MikroTik] ip firewall nat>
And the access to public FTP servers is denied in firewall:
[admin@MikroTik] ip firewall filter> print Flags: X - disabled, I - invalid, D - dynamic 0 chain=forward action=drop src-address=192.168.0.0/24 dst-port=21 protocol=tcp [admin@MikroTik] ip firewall filter>
We need to enable the SOCKS server:
enabled: yes
port: 1080
Add access to a client with an IP address 192.168.0.2/32 to SOCKS access list, allow data transfer from FTP server to client (allow destionation ports from 1024 to 65535 for any IP address), and drop everything else:
[admin@MikroTik] ip socks access> add src-address=192.168.0.2 dst-port=21 \ \... action=allow [admin@MikroTik] ip socks access> add dst-port=1024-65535 action=allow [admin@MikroTik] ip socks access> add action=deny [admin@MikroTik] ip socks access> print Flags: X - disabled 0 src-address=192.168.0.2 dst-port=21 action=allow 1 dst-port=1024-65535 action=allow 2 action=deny [admin@MikroTik] ip socks access>
That's all - the SOCKS server is configured. To see active connections and data transmitted and received:
[admin@MikroTik] ip socks connections> print # SRC-ADDRESS DST-ADDRESS TX RX 0 192.168.0.2:1238 10.5.8.8:21 1163 4625 1 192.168.0.2:1258 10.5.8.8:3423 0 3231744 [admin@MikroTik] ip socks connections>
Note! In order to use SOCKS proxy server, you have to specify its IP address and port in your FTP client. In this case IP address would be 192.168.0.1 (local IP address of the router/SOCKS server) and TCP port 1080.
