Log Management
| Document revision: | 2.3 (Mon Jul 19 07:23:35 GMT 2004) |
| Applies to: | V2.9 |
General Information
Summary
Various system events and status information can be logged. Logs can be saved in local routers file, displayed in console, sent to an email or to a remote server running a syslog daemon. MikroTik provides a shareware Windows Syslog daemon, which can be downloaded from www.mikrotik.com
Specifications
Packages required: systemLicense required: Level1
Submenu level: /system logging, /log
Standards and Technologies: Syslog
Hardware usage: Not significant
Related Documents
Description
Logs have different groups or topics. Logs from each topic can be configured to be discarded, logged locally or remotely. Locally log files can be stored in memory (default; logs are lost on reboot) or on hard drive (not enabled by default as is harmful for flash disks).
General Settings
Submenu level: /system loggingProperty Description
topics (info | critical | firewall | keepalive | packet | read | timer | write | ddns | hotspot | l2tp | ppp | route | update | account | debug | ike | manager | pppoe | script | warning | async | dhcp | info | notification | pptp | state | watchdog | bgp | error | ipsec | open | radius | system | web-proxy | calc | event | isdn | ospf | raw | telephony | wireless; default: info) - specifies log group or log message typeaction (disk | echo | memory | remote; default: memory) - specifies one of the system actions or user specified action listed in /system logging action prefix (name) - local log prefixExample
To logg messages that are generated by firewall by saving them in local buffer
[admin@MikroTik] system logging> add topics=firewall action=memory [admin@MikroTik] system logging> print Flags: X - disabled, I - invalid # TOPICS ACTION PREFIX 0 info memory 1 error memory 2 warning memory 3 critical echo 4 firewall memory [admin@MikroTik] system logging>
Actions
Submenu level: /system logging actionProperty Description
disk-lines (integer; default: 100) - Used when target is set to type disk. Specifies the number of records in log filedisk-stop-on-full (yes | no; default: no) - Used when target is set to type disk. Specifies whether to stop to save log messages on disk after the specified disk-lines number is reachedemail-to (name) - Used when target is set to type email, sets email address logs are sent tomemory-lines (integer; default: 100) - Used when target is set to type memory. Specifies the number of records in local buffer.memory-stop-on-full (yes | no; default: no) - Used when target is set to type memory. Specifies whether to stop to save log messages in local buffer after the specified memory-lines number is reachedname (name) - name of an actionremember (yes | no; default: yes) - Used when target is set to type echo. Specifies whether to keep log messages, which have not yet been displayed in consoleremote (IP address:port | IP address:integer: 0..65535; default: 0.0.0.0:514) - Used when target is set to type remote. Remote log server's IP address and UDP porttarget (disk | echo | email | memory | remote; default: memory) - Specifies how to treat logsecho - logs are displayed in console
email - logs are sent by email
memory - logs are saved to local buffer. They can be viewed using the '/log print' command
remote - logs are sent to remote host
Notes
You cannot delete or rename default actions.
Example
To add a new action with name short, that will save logs in local buffer, if number of records in buffer are less than 50:
[admin@MikroTik] system logging action> add name=short \ \... target=memory memory-lines=50 memory-stop-on-full=yes [admin@MikroTik] system logging action> print # FACILITY LOCAL REMOTE PREFIX REMOTE-ADDRESS REMOTE-PORT ECHO Flags: * - default # NAME TARGET REMOTE 0 * memory memory 1 * disk disk 2 * echo echo 3 * remote remote 0.0.0.0:514 4 short memory [admin@MikroTik] system logging action>
Log Messages
Submenu level: /logDescription
Displays locally stored log messages
message (text) - message texttime (text) - date and time of the eventCommand Description
print - shows log messagesExample
To view the local logs:
[admin@MikroTik] > log print TIME MESSAGE dec/24/2003 08:20:36 log configuration changed by admin dec/24/2003 08:20:36 log configuration changed by admin dec/24/2003 08:20:36 log configuration changed by admin dec/24/2003 08:20:36 log configuration changed by admin dec/24/2003 08:20:36 log configuration changed by admin dec/24/2003 08:20:36 log configuration changed by admin -- [Q quit|D dump]
To monitor the system log:
[admin@MikroTik] > log print follow TIME MESSAGE dec/24/2003 08:20:36 log configuration changed by admin dec/24/2003 08:24:34 log configuration changed by admin dec/24/2003 08:24:51 log configuration changed by admin dec/24/2003 08:25:59 log configuration changed by admin dec/24/2003 08:25:59 log configuration changed by admin dec/24/2003 08:30:05 log configuration changed by admin dec/24/2003 08:30:05 log configuration changed by admin dec/24/2003 08:35:56 system started dec/24/2003 08:35:57 isdn-out1: initializing... dec/24/2003 08:35:57 isdn-out1: dialing... dec/24/2003 08:35:58 Prism firmware loading: OK dec/24/2003 08:37:48 user admin logged in from 10.1.0.60 via telnet -- Ctrl-C to quit. New entries will appear at bottom.
