Xpeed SDSL Interface
Document revision:1.1 (Fri Mar 05 08:18:04 GMT 2004)
Applies to: V2.9
General Information
Summary
The MikroTik RouterOS supports the Xpeed 300 SDSL PCI Adapter hardware with speeds up to 2.32Mbps. This device can operate either using Frame Relay or PPP type of connection. SDSL (Single-line Digital Subscriber Line or Symmetric Digital Subscriber Line) stands for the type of DSL that uses only one of the two cable pairs for transmission. SDSL allows residential or small office users to share the same telephone for data transmission and voice or fax telephony.
Specifications
Packages required: synchronous
License required: Level4
Submenu level: /interface xpeed
Standards and Technologies: PPP (RFC 1661), Frame Relay (RFC 1490)
Hardware usage: Not significant
Related Documents
Additional Resources
Xpeed Interface Configuration
Property Description
name (name) - interface name
mtu (integer; default: 1500) - Maximum Transmission Unit
mac-address (MAC address) - MAC address of the card
arp (disabled | enabled | proxy-arp | reply-only; default: enabled) - Address Resolution Protocol
disabled - the interface will not use ARP protocol
enabled - the interface will use ARP protocol
proxy-arp - the interface will be an ARP proxy
reply-only - the interface will only reply to the requests originated to its own IP addresses, but neighbor MAC addresses will be gathered from /ip arp statically set table only
mode (network-termination | line-termination; default: line-termination) - interface mode, either line termination (LT) or network termination (NT)
sdsl-speed (integer; default: 2320) - SDSL connection speed
sdsl-invert (yes | no; default: no) - whether the clock is phase inverted with respect to the Transmitted Data interchange circuit. This configuration option is useful when long cable lengths between the Termination Unit and the DTE are causing data errors
sdsl-swap (yes | no; default: no) - whether or not the Xpeed 300 SDSL Adapter performs bit swapping. Bit swapping can maximize error performance by attempting to maintain an acceptable margin for each bin by equalizing the margin across all bins through bit reallocation
bridged-ethernet (yes | no; default: yes) - if the adapter operates in bridged Ethernet mode
dlci (integer; default: 16) - defines the DLCI to be used for the local interface. The DLCI field identifies which logical circuit the data travels over
lmi-mode (off | line-termination | network-termination | network-termination-bidirectional; default: off) - defines how the card will perform LMI protocol negotiation
off - no LMI will be used
line-termination - LMI will operate in LT (Line Termination) mode
network-termination - LMI will operate in NT (Network Termination) mode
network-termination-bidirectional - LMI will operate in bidirectional NT mode
cr (0 | 2; default: 0) - a special mask value to be used when speaking with certain buggy vendor equipment. Can be 0 or 2
Example
To enable interface:
[admin@r1] interface> print
Flags: X - disabled, D - dynamic, R - running
  #    NAME                                              TYPE             MTU
  0  R outer                                             ether            1500
  1  R inner                                             ether            1500
  2 X  xpeed1                                            xpeed            1500
[admin@r1] interface> enable 2
  #    NAME                                              TYPE             MTU
  2  R xpeed1                                            xpeed            1500
Frame Relay Configuration Examples
MikroTik Router to MikroTik Router
Consider the following network setup with MikroTik router connected via SDSL line using Xpeed interface to another MikroTik router with Xpeed 300 SDSL adapter. SDSL line can refer a common patch cable included with the Xpeed 300 SDSL adapter (such a connection is called Back-to-Back). Lets name the first router r1 and the second r2.
Router r1 setup
The following setup is identical to one in the first example:
[admin@r1] ip address> add inter=xpeed1 address 1.1.1.1/24
[admin@r1] ip address> pri
  #   ADDRESS            NETWORK         BROADCAST       INTERFACE
  0   1.1.1.1/24         1.1.1.0         1.1.1.255       xpeed1
[admin@r1] interface xpeed> print
Flags: X - disabled
  0   name="xpeed1" mtu=1500 mac-address=00:05:7A:00:00:08 arp=enabled
      mode=network-termination sdsl-speed=2320 sdsl-invert=no sdsl-swap=no
      bridged-ethernet=yes dlci=16 lmi-mode=off cr=0
Router r2 setup
First, we need to add a suitable IP address:
[admin@r2] ip address> add inter=xpeed1 address 1.1.1.2/24
[admin@r2] ip address> pri
  0   1.1.1.2/24         1.1.1.0         1.1.1.255       xpeed1
Then, some changes in xpeed interface configuration should be done:
[admin@r2] interface xpeed> print
Flags: X - disabled
[admin@r2] interface xpeed> set 0 mode=line-termination
Now r1 and r2 can ping each other.
MikroTik Router to Cisco Router
Let us consider the following network setup with MikroTik Router with Xpeed interface connected to a leased line with a CISCO router at the other end.
MikroTik router setup:
Flags: X - disabled
      bridged-ethernet=yes dlci=42 lmi-mode=off cr=0
Cisco router setup
CISCO# show running-config
Building configuration...
Current configuration...
ip subnet-zero
no ip domain-lookup
frame-relay switching
interface Ethernet0
 description connected to EthernetLAN
 ip address 10.0.0.254 255.255.255.0
interface Serial0
 description connected to Internet
 no ip address
 encapsulation frame-relay IETF
 serial restart-delay 1
 frame-relay lmi-type ansi
 frame-relay intf-type dce
interface Serial0.1 point-to-point
 ip address 1.1.1.2 255.255.255.0
 no arp frame-relay
 frame-relay interface-dlci 42
end.
Send ping to MikroTik router
CISCO#ping 1.1.1.1
Type escape sequence to abort.
Sending 5, 100-byte ICMP Echos to 1.1.1.1, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 28/31/32 ms
CISCO#
Troubleshooting
Description
