VLAN
| Document revision: | 1.2 (Mon Sep 19 13:46:34 GMT 2005) |
| Applies to: | V2.9 |
General Information
Summary
VLAN is an implementation of the 802.1Q VLAN protocol for MikroTik RouterOS. It allows you to have multiple Virtual LANs on a single ethernet or wireless interface, giving the ability to segregate LANs efficiently. It supports up to 4095 vlan interfaces, each with a unique VLAN ID, per ethernet device. Many routers, including Cisco and Linux based, and many Layer 2 switches also support it.
A VLAN is a logical grouping that allows end users to communicate as if they were physically connected to a single isolated LAN, independent of the physical configuration of the network. VLAN support adds a new dimension of security and cost savings permitting the sharing of a physical network while logically maintaining separation among unrelated users.
Specifications
Packages required: systemLicense required: Level1 (limited to 1 vlan) , Level3
Submenu level: /interface vlan
Standards and Technologies: VLAN (IEEE 802.1Q)
Hardware usage: Not significant
Related Documents
Description
VLANs are simply a way of grouping a set of switch ports together so that they form a logical network, separate from any other such group. Within a single switch this is straightforward local configuration. When the VLAN extends over more than one switch, the inter-switch links have to become trunks, on which packets are tagged to indicate which VLAN they belong to.
You can use MikroTik RouterOS (as well as Cisco IOS and Linux) to mark these packets as well as to accept and route marked ones.
As VLAN works on OSI Layer 2, it can be used just as any other network interface without any restrictions. And VLAN successfully passes through Ethernet bridges (for MikroTik RouterOS bridges you should set forward-protocols to ip, arp and other; for other bridges there should be analogical settings).
You can also transport VLANs over wireless links and put multiple VLAN interfaces on a single wireless interface. Note that as VLAN is not a full tunnel protocol (i.e., it does not have additional fields to transport MAC addresses of sender and recipient), the same limitation applies to bridging over VLAN as to bridging plain wireless interfaces. In other words, while wireless clients may participate in VLANs put on wireless interfaces, it is not possible to have VLAN put on a wireless interface in station mode bridged with any other interface.
Currently supported Ethernet interfacesThis is a list of network interfaces on which VLAN was tested and worked. Note that there might be many other interfaces that support VLAN, but they just were not checked.
- Realtek 8139
- Intel PRO/100
- Intel PRO1000 server adapter
- National Semiconductor DP83816 based cards (RouterBOARD200 onboard Ethernet, RouterBOARD 24 card)
- National Semiconductor DP83815 (Soekris onboard Ethernet)
- VIA VT6105M based cards (RouterBOARD 44 card)
- VIA VT6105
- VIA VT6102 (VIA EPIA onboard Ethernet)
This is a list of network interfaces on which VLAN was tested and worked, but WITHOUT LARGE PACKET (>1496 bytes) SUPPORT:
- 3Com 3c59x PCI
- DEC 21140 (tulip)
Additional Resources
- http://www.csd.uwo.ca/courses/CS457a/reports/handin/jpbojtos/A2/trunking.htm
- http://www.cisco.com/univercd/cc/td/doc/product/software/ios121/121newft/121t/121t3/dtbridge.htm#xtocid114533
- http://www.cisco.com/warp/public/473/27.html#tagging
- http://www.cisco.com/warp/public/538/7.html
- http://www.nwfusion.com/news/tech/2001/0305tech.html
- http://www.intel.com/network/connectivity/resources/doc_library/tech_brief/virtual_lans.htm
VLAN Setup
Submenu level: /interface vlanProperty Description
arp (disabled | enabled | proxy-arp | reply-only; default: enabled) - Address Resolution Protocol settingenabled - the interface will use ARP protocol
proxy-arp - the interface will be an ARP proxy
reply-only - the interface will only reply to the requests originated to its own IP addresses, but neighbor MAC addresses will be gathered from /ip arp statically set table only
Notes
MTU should be set to 1500 bytes as on Ethernet interfaces. But this may not work with some Ethernet cards that do not support receiving/transmitting of full size Ethernet packets with VLAN header added (1500 bytes data + 4 bytes VLAN header + 14 bytes Ethernet header). In this situation MTU 1496 can be used, but note that this will cause packet fragmentation if larger packets have to be sent over interface. At the same time remember that MTU 1496 may cause problems if path MTU discovery is not working properly between source and destination.
Example
To add and enable a VLAN interface named test with vlan-id=1 on interface ether1:
[admin@MikroTik] interface vlan> add name=test vlan-id=1 interface=ether1 [admin@MikroTik] interface vlan> print Flags: X - disabled, R - running # NAME MTU ARP VLAN-ID INTERFACE 0 X test 1500 enabled 1 ether1 [admin@MikroTik] interface vlan> enable 0 [admin@MikroTik] interface vlan> print Flags: X - disabled, R - running # NAME MTU ARP VLAN-ID INTERFACE 0 R test 1500 enabled 1 ether1 [admin@MikroTik] interface vlan>
Application Example
VLAN example on MikroTik Routers
Let us assume that we have two or more MikroTik RouterOS routers connected with a hub. Interfaces to the physical network, where VLAN is to be created is ether1 for all of them (it is needed only for example simplification, it is NOT a must).
To connect computers through VLAN they must be connected physically and unique IP addresses should be assigned them so that they could ping each other. Then on each of them the VLAN interface should be created:
[admin@MikroTik] interface vlan> add name=test vlan-id=32 interface=ether1 [admin@MikroTik] interface vlan> print Flags: X - disabled, R - running # NAME MTU ARP VLAN-ID INTERFACE 0 R test 1500 enabled 32 ether1 [admin@MikroTik] interface vlan>
If the interfaces were successfully created, both of them will be running. If computers are connected incorrectly (through network device that does not retransmit or forward VLAN packets), either both or one of the interfaces will not be running.
When the interface is running, IP addresses can be assigned to the VLAN interfaces.
On the Router 1:
[admin@MikroTik] ip address> add address=10.10.10.1/24 interface=test [admin@MikroTik] ip address> print Flags: X - disabled, I - invalid, D - dynamic # ADDRESS NETWORK BROADCAST INTERFACE 0 10.0.0.204/24 10.0.0.0 10.0.0.255 ether1 1 10.20.0.1/24 10.20.0.0 10.20.0.255 pc1 2 10.10.10.1/24 10.10.10.0 10.10.10.255 test [admin@MikroTik] ip address>
On the Router 2:
[admin@MikroTik] ip address> add address=10.10.10.2/24 interface=test [admin@MikroTik] ip address> print Flags: X - disabled, I - invalid, D - dynamic # ADDRESS NETWORK BROADCAST INTERFACE 0 10.0.0.201/24 10.0.0.0 10.0.0.255 ether1 1 10.10.10.2/24 10.10.10.0 10.10.10.255 test [admin@MikroTik] ip address>
If it set up correctly, then it is possible to ping Router 2 from Router 1 and vice versa:
[admin@MikroTik] ip address> /ping 10.10.10.1 10.10.10.1 64 byte pong: ttl=255 time=3 ms 10.10.10.1 64 byte pong: ttl=255 time=4 ms 10.10.10.1 64 byte pong: ttl=255 time=10 ms 10.10.10.1 64 byte pong: ttl=255 time=5 ms 4 packets transmitted, 4 packets received, 0% packet loss round-trip min/avg/max = 3/10.5/10 ms [admin@MikroTik] ip address> /ping 10.10.10.2 10.10.10.2 64 byte pong: ttl=255 time=10 ms 10.10.10.2 64 byte pong: ttl=255 time=11 ms 10.10.10.2 64 byte pong: ttl=255 time=10 ms 10.10.10.2 64 byte pong: ttl=255 time=13 ms 4 packets transmitted, 4 packets received, 0% packet loss round-trip min/avg/max = 10/11/13 ms [admin@MikroTik] ip address>
