MOXA C101 Synchronous Interface
Document revision:1.1 (Fri Mar 05 08:15:42 GMT 2004)
Applies to: V2.9
General Information
Summary
The MikroTik RouterOS supports MOXA C101 Synchronous 4Mb/s Adapter hardware. The V.35 synchronous interface is the standard for VSAT and other satellite modems. However, you must check with the satellite system supplier for the modem interface type.
Specifications
Packages required: synchronous
License required: Level4
Submenu level: /interface moxa-c101
Standards and Technologies: Cisco/HDLC-X.25 (RFC 1356), Frame Relay (RFC1490), PPP (RFC-1661), PPP (RFC-1662)
Hardware usage: Not significant
Related Documents
Description
You can install up to four MOXA C101 synchronous cards in one PC box, if you have so many slots and IRQs available. Assuming you have all necessary packages and licenses installed, in most cases it should to be done nothing at that point (all drivers are loaded automatically). However, if you have a non Plug-and-Play ISA card, the corresponding driver requires to be loaded.
MOXA C101 PCI variant cabling
The MOXA C101 PCI requires different from MOXA C101 ISA cable. It can be made using the following table:
DB25f Signal Direction V.35m
4 RTS OUT C
5 CTS IN D
6 DSR IN E
7 GND - B
8 DCD IN F
10 TxDB OUT S
11 TxDA OUT P
12 RxDB IN T
13 RxDA IN R
14 TxCB IN AA
16 TxCA IN Y
20 DTR OUT H
22 RxCB IN X
23 RxCA IN V
short 9 and 25 pin
Additional Resources
For more information about the MOXA C101 synchronous 4Mb/s adapter hardware please see:
Synchronous Interface Configuration
Description
Moxa c101 synchronous interface is shown under the interfaces list with the name moxa-c101-N
Property Description
name (name; default: moxa-c101-N) - interface name
cisco-hdlc-keepalive-interval (time; default: 10s) - keepalive period in seconds
clock-rate (integer; default: 64000) - speed of internal clock
clock-source (external | internal | tx-from-rx | tx-internal; default: external) - clock source
frame-relay-dce (yes | no; default: no) - operate or not in DCE mode
frame-relay-lmi-type (ansi | ccitt; default: ansi) - Frame-relay Local Management Interface type:
ansi - set LMI type to ANSI-617d (also known as Annex A)
ccitt - set LMI type to CCITT Q933a (also known as Annex A)
ignore-dcd (yes | no; default: no) - ignore or not DCD
line-protocol (cisco-hdlc | frame-relay | sync-ppp; default: sync-ppp) - line protocol name
mtu (integer; default: 1500) - Maximum Transmit Unit
Notes
If you purchased the MOXA C101 Synchronous card from MikroTik, you have received a V.35 cable with it. This cable should work for all standard modems, which have V.35 connections. For synchronous modems, which have a DB-25 connection, you should use a standard DB-25 cable.
The MikroTik driver for the MOXA C101 Synchronous adapter allows you to unplug the V.35 cable from one modem and plug it into another modem with a different clock speed, and you do not need to restart the interface or router.
Example
[admin@MikroTik] interface> moxa-c101
[admin@MikroTik] interface moxa-c101> print
  0  R name="moxa-c101-1" mtu=1500 line-protocol=sync-ppp clock-rate=64000
       clock-source=external frame-relay-lmi-type=ansi frame-relay-dce=no
       cisco-hdlc-keepalive-interval=10s ignore-dcd=no
You can monitor the status of the synchronous interface:
[admin@MikroTik] interface moxa-c101> monitor 0
    dtr: yes
    rts: yes
    cts: no
    dsr: no
    dcd: no
Connect a communication device, e.g., a baseband modem, to the V.35 port and turn it on. If the link is working properly the status of the interface is:
    dtr: yes
    rts: yes
    cts: yes
    dsr: yes
    dcd: yes
Troubleshooting
Description
Synchronous Link Application Examples
MikroTik Router to MikroTik Router
Let us consider the following network setup with two MikroTik Routers connected to a leased line with baseband modems:
The driver for MOXA C101 card should be loaded and the interface should be enabled according to the instructions given above. The IP addresses assigned to the synchronous interface should be as follows:
[admin@MikroTik] ip address> add address 1.1.1.1/32 interface wan \
\... network 1.1.1.2 broadcast 255.255.255.255
[admin@MikroTik] ip address> print
  #   ADDRESS            NETWORK         BROADCAST       INTERFACE
  0   10.0.0.254/24      10.0.0.254      10.0.0.255      ether2
  1   192.168.0.254/24   192.168.0.254   192.168.0.255   ether1
  2   1.1.1.1/32         1.1.1.2         255.255.255.255 wan
[admin@MikroTik] ip address> /ping 1.1.1.2
1.1.1.2 64 byte pong: ttl=255 time=31 ms
1.1.1.2 64 byte pong: ttl=255 time=26 ms
3 packets transmitted, 3 packets received, 0% packet loss
round-trip min/avg/max = 26/27.6/31 ms
The default route should be set to the gateway router 1.1.1.2:
[admin@MikroTik] ip route> add gateway 1.1.1.2
[admin@MikroTik] ip route> print
Flags: X - disabled, I - invalid, D - dynamic, J - rejected,
C - connect, S - static, R - rip, O - ospf, B - bgp
    #    DST-ADDRESS        G GATEWAY         DISTANCE INTERFACE
    0  S 0.0.0.0/0          r 1.1.1.2         1        wan
    1 DC 10.0.0.0/24        r 10.0.0.254      1        ether2
    2 DC 192.168.0.0/24     r 192.168.0.254   0        ether1
    3 DC 1.1.1.2/32         r 0.0.0.0         0        wan
The configuration of the MikroTik router at the other end is similar:
[admin@MikroTik] ip address> add address 1.1.1.2/32 interface moxa \
\... network 1.1.1.1 broadcast 255.255.255.255
  0   10.1.1.12/24       10.1.1.12       10.1.1.255      Public
  1   1.1.1.2/32         1.1.1.1         255.255.255.255 moxa
[admin@MikroTik] ip address> /ping 1.1.1.1
1.1.1.1 64 byte pong: ttl=255 time=31 ms
1.1.1.1 64 byte pong: ttl=255 time=26 ms
MikroTik Router to Cisco Router
Let us consider the following network setup with MikroTik Router connected to a leased line with baseband modems and a CISCO router at the other end:
    1 DC 10.0.0.0/24        r 10.0.0.254      0        ether2
    3 DC 1.1.1.2/32         r 1.1.1.1         0        wan
The configuration of the Cisco router at the other end (part of the configuration) is:
CISCO#show running-config
Building configuration...
Current configuration:
interface Ethernet0
 description connected to EthernetLAN
 ip address 10.1.1.12 255.255.255.0
interface Serial0
 description connected to MikroTik
 ip address 1.1.1.2 255.255.255.252
 serial restart-delay 1
ip classless
ip route 0.0.0.0 0.0.0.0 10.1.1.254
end
CISCO#
Send ping packets to the MikroTik router:
CISCO#ping 1.1.1.1
Type escape sequence to abort.
Sending 5, 100-byte ICMP Echos to 1.1.1.1, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 28/32/40 ms
CISCO#
Note! Keep in mind that for the point-to-point link the network mask is set to 32 bits, the argument network is set to the IP address of the other end, and the broadcast address is set to 255.255.255.255.
