ISDN (Integrated Services Digital Network) Interface
Document revision:1.1 (Fri Mar 05 08:15:11 GMT 2004)
Applies to: V2.9
General Information
Summary
The MikroTik router can act as an ISDN client for dialing out, or as an ISDN server for accepting incoming calls. The dial-out connections may be set as dial-on-demand or as permanent connections (simulating a leased line). The remote IP address (provided by the ISP) can be used as the default gateway for the router.
Specifications
Packages required: isdn, ppp
License required: Level1
Submenu level: /interface isdn-server, /interface isdn-client
Standards and Technologies: PPP (RFC 1661)
Hardware usage: Not significant
Related Documents
Additional Resources
ISDN Hardware and Software Installation
Command name: /driver add
Description
Please install the ISDN adapter into the PC accordingly the instructions provided by the adapter manufacturer.
Appropriate packages have to be downloaded from MikroTik??????s web page http://www.mikrotik.com. After all, the ISDN driver should be loaded using the /driver add command.
MikroTik RouterOS supports passive PCI adapters with Siemens chipset:
For example, for the HFC based PCI card, it is enough to use /driver add name=hfc command to get the driver loaded.
Note! ISDN ISA adapters are not supported!
Property Description
name (name) - name of the driver
isdn-protocol (euro | german; default: euro) - data channel protocol
ISDN Channels
ISDN channels are added to the system automatically when the ISDN card driver is loaded. Each channel corresponds to one physical 64K ISDN data channel.
The list of available ISDN channels can be viewed using the /isdn-channels print command. The channels are named channel1, channel2, and so on. E.g., if you have two ISDN channels, and one of them currently used by an ISDN interface, but the other available, the output should look like this:
[admin@MikroTik] isdn-channels> print
Flags: X - disabled, E - exclusive
  #    NAME                     CHANNEL    DIR.. TYPE  PHONE
  0    channel1                 0
  1    channel2                 1
ISDN channels are very similar to PPP serial ports. Any number of ISDN interfaces can be configured on a single channel, but only one interface can be enabled for that channel at a time. It means that every ISDN channel is either available or used by an ISDN interface.
MSN and EAZ numbers
In Euro-ISDN a subscriber can assign more than one ISDN number to an ISDN line. For example, an ISDN line could have the numbers 1234067 and 1234068. Each of these numbers can be used to dial the ISDN line. These numbers are referred to as Multiple Subscriber Numbers (MSN).
A similar, but separate concept is EAZ numbering, which is used in German ISDN networking. EAZ number can be used in addition to dialed phone number to specify the required service.
For dial-out ISDN interfaces, MSN/EAZ number specifies the outgoing phone number (the calling end). For dial-in ISDN interfaces, MSN/EAZ number specifies the phone number that will be answered. If you are unsure about your MSN/EAZ numbers, leave them blank (it is the default).
For example, if your ISDN line has numbers 1234067 and 1234068, you could configure your dial-in server to answer only calls to 1234068 by specifying 1234068 as your MSN number. In a sense, MSN is just your phone number.
ISDN Client Interface Configuration
Submenu level: /interface isdn-client
Description
The ISDN client is used to connect to remote dial-in server (probably ISP) via ISDN. To set up an ISDN dial-out connection, use the ISDN dial-out configuration menu under the submenu.
name (name; default: isdn-outN) - interface name
mtu (integer; default: 1500) - Maximum Transmission Unit
mru (integer; default: 1500) - Maximum Receive Unit
phone (integer; default: "") - phone number to dial
msn (integer; default: "") - MSN/EAZ of ISDN line provided by the line operator
dial-on-demand (yes | no; default: no) - use dialing on demand
l2-protocol (hdlc | x75i | x75ui | x75bui; default: hdlc) - level 2 protocol to be used
user (text) - user name that will be provided to the remote server
password (text) - password that will be provided to the remote server
allow (multiple choice: mschap2, mschap1, chap, pap; default: mschap2, mschap1, chap, pap) - the protocol to allow the client to use for authentication
add-default-route (yes | no; default: no) - add default route to remote host on connect
profile (name; default: default) - profile to use when connecting to the remote server
use-peer-dns (yes | no; default: no) - use or not peer DNS
bundle-128K (yes | no; default: yes) - use both channels instead of just one
Example
ISDN client interfaces can be added using the add command:
[admin@MikroTik] interface isdn-client> add msn="142" user="test" \
\... password="test" phone="144" bundle-128K=no
[admin@MikroTik] interface isdn-client> print
  0 X  name="isdn-out1" mtu=1500 mru=1500 msn="142" user="test"
       password="test" profile=default phone="144" l2-protocol=hdlc
       bundle-128K=no dial-on-demand=no add-default-route=no use-peer-dns=no
ISDN Server Interface Configuration
Description
ISDN server is used to accept remote dial-in connections form ISDN clients.
name (name; default: isdn-inN) - interface name
authentication (pap | chap | mschap1 | mschap2; default: mschap2, mschap1, chap, pap) - used authentication
Example
ISDN server interfaces can be added using the add command:
[admin@MikroTik] interface isdn-server> add msn="142" bundle-128K=no
[admin@MikroTik] interface isdn-server> print
  0 X  name="isdn-in1" mtu=1500 mru=1500 msn="142"
       authentication=mschap2,chap,pap profile=default l2-protocol=x75bui
       bundle-128K=no
ISDN Examples
ISDN Dial-out
Dial-out ISDN connections allow a local router to connect to a remote dial-in server (ISP's) via ISDN.
Let's assume you would like to set up a router that connects your local LAN with your ISP via ISDN line. First you should load the corresponding ISDN card driver. Supposing you have an ISDN card with a W6692-based chip:
[admin@MikroTik]> /driver add name=w6692
Now additional channels should appear. Assuming you have only one ISDN card driver loaded, you should get following:
  0    channel1                   0
  1    channel2                   1
Suppose you would like to use dial-on-demand to dial your ISP and automatically add a default route to it. Also, you would like to disconnect when there is more than 30s of network inactivity. Your ISP's phone number is 12345678 and the user name for authentication is 'john'. Your ISP assigns IP addresses automatically. Add an outgoing ISDN interface and configure it in the following way:
[admin@mikrotik]> /interface isdn-client add name="isdn-isp" phone="12345678"
user="john" password="31337!)" add-default-route=yes dial-on-demand=yes
[admin@MikroTik] > /interface isdn-client print
  0 X  name="isdn-isp" mtu=1500 mru=1500 msn="" user="john" password="31337!)"
       profile=default phone="12345678" l2-protocol=hdlc bundle-128K=no
       dial-on-demand=yes add-default-route=yes use-peer-dns=no
Configure PPP profile.
[admin@MikroTik] ppp profile> print
Flags: * - default
  0 * name="default" local-address=0.0.0.0 remote-address=0.0.0.0
      session-timeout=0s idle-timeout=0s use-compression=no
      use-vj-compression=yes use-encryption=no require-encryption=no only-one=no
      tx-bit-rate=0 rx-bit-rate=0 incoming-filter="" outgoing-filter=""
[admin@Mikrotik] ppp profile> set default idle-timeout=30s
If you would like to remain connected all the time, i.e., as a leased line, then set the idle-timeout to 0s.
All that remains is to enable the interface:
[admin@MikroTik] /interface set isdn-isp disabled=no
You can monitor the connection status with the following command:
[admin@MikroTik] /interface isdn-client monitor isdn-isp
ISDN Dial-in
Dial-in ISDN connections allow remote clients to connect to your router via ISDN.
Let us assume you would like to configure a router for accepting incoming ISDN calls from remote clients. You have an Ethernet card connected to the LAN, and an ISDN card connected to the ISDN line. First you should load the corresponding ISDN card driver. Supposing you have an ISDN card with an HFC chip:
[admin@MikroTik] /driver add name=hfc
Now additional channels should appear. Assuming you have only one ISDN card driver loaded, you should get the following:
  0    channel1                   0
  1    channel2                   1
Add an incoming ISDN interface and configure it in the following way:
[admin@MikroTik] interface isdn-server> add msn="7542159" \
\... authentication=chap,pap bundle-128K=no
Flags: X - disabled
  0 X  name="isdn-in1" mtu=1500 mru=1500 msn="7542159" authentication=chap,pap
       profile=default l2-protocol=hldc bundle-128K=no
Configure PPP settings and add users to router's database.
Flags: * - default
[admin@Mikrotik] ppp profile> set default idle-timeout=5s local-address=10.99.8.1 \
\... remote-address=10.9.88.1
Add user 'john' to the router's user database. Assuming that the password is '31337!)':
[admin@MikroTik] ppp secret> add name=john password="31337!)" service=isdn
[admin@MikroTik] ppp secret> print
Flags: X - disabled
  #   NAME              SERVICE CALLER-ID        PASSWORD         PROFILE
  0   john              isdn                     31337!)          default
Check the status of the ISDN server interface and wait for the call:
[admin@MikroTik] interface isdn-server> monitor isdn-in1
    status: Waiting for call...
ISDN Backup
Backup systems are used in specific cases, when you need to maintain a connection, even if a fault occurs. For example, if someone cuts the wires, the router can automatically connect to a different interface to continue its work. Such a backup is based on an utility that monitors the status of the connection - netwatch, and a script, which runs the netwatch.
This is an example of how to make simple router backup system. In this example we'll use an ISDN connection for purpose to backup a standard Ethernet connection. You can, however, use instead of the ISDN connection anything you need - PPP, for example. When the Ethernet fail (the router nr.1 cannot ping the router nr.2 to 2.2.2.2 (see picture) the router nr.1 will establish an ISDN connection, so-called backup link, to continue communicating with the nr. 2.
You must keep in mind, that in our case there are just two routers, but this system can be extended to support more different networks.
The backup system example is shown in the following picture:
In this case the backup interface is an ISDN connection, but in real applications it can be substituted by a particular connection. Follow the instructions below on how to set up the backup link:
