Cyclades PC300 PCI Adapters
Document revision: | 1.1 (Fri Mar 05 08:13:30 GMT 2004) |
Applies to: | V2.9 |
General Information
Summary
The MikroTik RouterOS supports the following Cyclades PC300 Adapter hardware:
- RSV/V.35 (RSV models) with 1 or 2 RS-232/V.35 interfaces on standard DB25/M.34 connector, 5Mbps, internal or external clock
- T1/E1 (TE models) with 1 or 2 T1/E1/G.703 interfaces on standard RJ48C connector, Full/Fractional, internal or external clock
- X.21 (X21 models) with 1 or 2 X.21 on standard DB-15 connector, 8Mbps, internal or external clock
Specifications
Packages required: synchronousLicense required: Level4
Submenu level: /interface cyclades
Standards and Technologies: X.21, X.35, T1/E1/G.703, Frame Relay, PPP, Cisco-HDLC
Hardware usage: Not significant
Related Documents
Synchronous Interface Configuration
Submenu level: /interface cycladesDescription
You can install up to four Cyclades PC300 PCI Adapters in one PC box, if you have so many adapter slots and IRQs available.
The Cyclades PC300/RSV Synchronous PCI Adapter comes with a V.35 cable. This cable should work for all standard modems, which have V.35 connections. For synchronous modems, which have a DB-25 connection, you should use a standard DB-25 cable.
Connect a communication device, e.g., a baseband modem, to the V.35 port and turn it on. The MikroTik driver for the Cyclades Synchronous PCI Adapter allows you to unplug the V.35 cable from one modem and plug it into another modem with a different clock speed, and you do not need to restart the interface or router.
Property Description
name (name; default: cycladesN) - descriptive interface name mtu (integer; default: 1500) - Maximum Transmission Unit for the interface line-protocol (cisco-hdlc | frame-relay | sync-ppp; default: sync-ppp) - line protocol media-type (E1 | T1 | V24 | V35 | X21; default: V35) - the hardware media used for this interface clock-rate (integer; default: 64000) - internal clock rate in bps clock-source (internal | external | tx-internal; default: external) - source clock line-code (AMI | B8ZS | HDB3 | NRZ; default: B8ZS) - for T1/E1 channels only. Line modulation method:B8ZS - Binary 8-Zero Substitution
HDB3 - High Density Bipolar 3 Code (ITU-T)
NRZ - Non-Return-To-Zero
D4 - Fourth Generation Channel Bank (48 Voice Channels on 2 T-1s or 1 T-1c)
ESF - Extended Superframe Format
Non-CRC4 - plain Cyclic Redundancy Check
Unframed - do not check frame integrity
Troubleshooting
Description
The cyclades interface does not show up under the interfaces list
Obtain the required license for synchronous feature
The synchronous link does not work
Check the V.35 cabling and the line between the modems. Read the modem manual
RSV/V.35 Synchronous Link Applications
Example
Let us consider the following network setup with MikroTik Router connected to a leased line with baseband modems and a CISCO router at the other end:
The driver for the Cyclades PC300/RSV Synchronous PCI Adapter should load automatically. The interface should be enabled according to the instructions given above. The IP addresses assigned to the cyclades interface should be as follows:
[admin@MikroTik] ip address> add address=1.1.1.1/32 interface=cyclades1 [admin@MikroTik] ip address> print Flags: X - disabled, I - invalid, D - dynamic # ADDRESS NETWORK BROADCAST INTERFACE 0 10.0.0.219/24 10.0.0.0 10.0.0.255 ether1 1 1.1.1.1/32 1.1.1.1 1.1.1.1 cyclades1 2 192.168.0.254/24 192.168.0.0 192.168.0.255 ether2 [admin@MikroTik] ip address> /ping 1.1.1.2 1.1.1.2 64 byte pong: ttl=255 time=12 ms 1.1.1.2 64 byte pong: ttl=255 time=8 ms 1.1.1.2 64 byte pong: ttl=255 time=7 ms 3 packets transmitted, 3 packets received, 0% packet loss round-trip min/avg/max = 7/9.0/12 ms [admin@MikroTik] ip address> /tool flood-ping 1.1.1.2 size=1500 count=50 sent: 50 received: 50 min-rtt: 1 avg-rtt: 1 max-rtt: 9 [admin@MikroTik] ip address>
Note that for the point-to-point link the network mask is set to 32 bits, the argument network is set to the IP address of the other end, and the broadcast address is set to 255.255.255.255. The default route should be set to gateway router 1.1.1.2:
[admin@MikroTik] ip route> add gateway 1.1.1.2 interface cyclades1 [admin@MikroTik] ip route> print Flags: X - disabled, I - invalid, D - dynamic, J - rejected, C - connect, S - static, R - rip, O - ospf, B - bgp # DST-ADDRESS G GATEWAY DISTANCE INTERFACE 0 S 0.0.0.0/0 r 1.1.1.2 1 cyclades1 1 DC 10.0.0.0/24 r 0.0.0.0 0 ether1 2 DC 192.168.0.0/24 r 0.0.0.0 0 ether2 3 DC 1.1.1.2/32 r 0.0.0.0 0 cyclades1 [admin@MikroTik] ip route>
The configuration of the CISCO router at the other end (part of the configuration) is:
CISCO#show running-config Building configuration... Current configuration: ... ! interface Ethernet0 description connected to EthernetLAN ip address 10.1.1.12 255.255.255.0 ! interface Serial0 description connected to MikroTik ip address 1.1.1.2 255.255.255.252 serial restart-delay 1 ! ip classless ip route 0.0.0.0 0.0.0.0 10.1.1.254 ! ... end CISCO# Send ping packets to the MikroTik router: CISCO#ping 1.1.1.1 Type escape sequence to abort. Sending 5, 100-byte ICMP Echos to 1.1.1.1, timeout is 2 seconds: !!!!! Success rate is 100 percent (5/5), round-trip min/avg/max = 28/32/40 ms CISCO#
