ARLAN 655 Wireless Client Card
| Document revision: | 1.1 (Fri Mar 05 08:12:25 GMT 2004) |
| Applies to: | V2.9 |
General Information
Summary
The MikroTik RouterOS supports Arlan 655 Wireless Interface client cards. This card fits in the ISA expansion slot and provides transparent wireless communications to other network nodes.
Specifications
Packages required: arlanLicense required: Level4
Submenu level: /interface arlan
Hardware usage: Not significant
Related Documents
Installation
Example
To add the driver for Arlan 655 adapter, do the following:
[admin@MikroTik]> driver add name=arlan io=0xD000 [admin@MikroTik]> driver print Flags: I - invalid, D - dynamic # DRIVER IRQ IO MEMORY ISDN-PROTOCOL 0 D RealTek 8139 1 Arlan 655 0xD000 [admin@MikroTik] driver>
Wireless Interface Configuration
Submenu level: /interface arlanDescription
The wireless card status can be obtained from the two LEDs: the Status LED and the Activity LED.
| Status | Activity | Description |
| Amber | Amber | ARLAN 655 is functional but nonvolatile memory is not configured |
| Blinking Green | Don't Care | ARLAN 655 not registered to an AP (ARLAN mode only) |
| Green | Off | Normal idle state |
| Green | Green Flash | Normal active state |
| Red | Amber | Hardware failure |
| Red | Red | Radio failure |
Property Description
name (name; default: arlanN) - assigned interface name mtu (integer; default: 1500) - Maximum Transmission Unit mac-address (MAC address) - Media Access Control address frequency (2412 | 2427 | 2442 | 2457 | 2465; default: 2412) - channel frequency in MHz bitrate (1000 | 2000 | 354 | 500; default: 2000) - data rate in Kbit/s sid (integer; default: 0x13816788) - System Identifier. Should be the same for all nodes on the radio network. Must be an even number with maximum length 31 character add-name (text; default: test) - card name (optional). Must contain less than 16 characters. arp (disabled | enabled | proxy-arp | reply-only; default: enabled) - Address Resolution Protocol setting tma-mode (yes | no; default: no) - Networking Registration Mode:no - NON ARLAN
Example
[admin@MikroTik] > interface print Flags: X - disabled, D - dynamic, R - running # NAME TYPE MTU 0 R outer ether 1500 1 X arlan1 arlan 1500 [admin@MikroTik] interface> enable 1 [admin@MikroTik] > interface print Flags: X - disabled, D - dynamic, R - running # NAME TYPE MTU 0 R outer ether 1500 1 R arlan1 arlan 1500
More configuration and statistics parameters can be found under the /interface arlan menu:
[admin@MikroTik] interface arlan> print
0 R name="arlan1" mtu=1500 mac-address=00:40:96:22:90:C8 arp=enabled
frequency=2412 bitrate=2000 tma-mode=no card-name="test"
sid=0x13816788
You can monitor the status of the wireless interface:
[admin@MikroTik] interface arlan> monitor 0
access-point: 00:00:00:00:00:00
backbone: 00:00:00:00:00:00
Suppose we want to configure the wireless interface to accomplish registration on the AP with a sid 0x03816788. To do this, it is enough to change the argument value of sid to 0x03816788 and tma-mode to yes:
[admin@MikroTik] interface arlan> set 0 sid=0x03816788 tma-mode=yes
access-point: 00:40:88:23:91:F8
backbone: 00:40:88:23:91:F9
Troubleshooting
Description
Keep in mind, that not all combinations of I/O base addresses and IRQs may work on particular motherboard. It is recommended that you choose an IRQ not used in your system, and then try to find an acceptable I/O base address setting. As it has been observed, the IRQ 5 and I/O 0x300 or 0x180 will work in most cases.
The driver cannot be loaded because other device uses the requested IRQ.
Try to set different IRQ using the DIP switches.
The requested I/O base address cannot be used on your motherboard.
Try to change the I/O base address using the DIP switches.
The pc interface does not show up under the interfaces list
Obtain the required license for 2.4/5GHz Wireless Client feature.
The wireless card does not register to the Access Point
Check the cabling and antenna alignment.
