evert
Number of connections?
Tue Oct 26, 2004 10:14 am
Hi everyone!
Who knows whether it's possible (with SNMP?) to poll a Mikrotik unit and find the total number of connections (/ip firewall connections ) this way?
Eugene
Forum Veteran
Forum Veteran
Tue Oct 26, 2004 10:30 am
It isn't possible.
gianluca
Tue Oct 26, 2004 12:43 pm
I see 2 ways
1. a script on the mikrotik, it send an email each time you want this data
2. from a remote server execute a script with telnet and retreive the info
evert
Tue Oct 26, 2004 12:48 pm
#2 sounds good! That I should be able to do from the same server that would have done the SNMP-fetch anyway... ;)
Do you have an example of such a script for me/us? :)
Eugene
Forum Veteran
Forum Veteran
Tue Oct 26, 2004 7:51 pm
A simple expect script may look like this:
#!/usr/bin/expect
#Information gathering script for RouterOS
# this will timeout the script if something go wrong
set timeout 20
# set these variables for your network
set router "1.1.1.2"
set logn "admin"
set passwd ""
set rta_prompt ".* >"
# Setting loglevel 0 to avoid spamming from router
log_user 0
# Spawning quiet telnet session
eval spawn -noecho telnet "$router"
# Authentication stuff
expect "Login:" {send "$logn\r"}
expect "Password:" {send "$passwd\r"}
# Retrieve and print info about connections
expect "$rta_prompt" {
  send "/ip firewall connection print\r"
  set aa $expect_out(buffer);
  send_user "\n-------------------------------\n";
  send_user $aa;
sleep 2
send "\r"
Note that you must have TCL and Expect installed in order to get this script work. And I guess this should be *nix machine:)
evert
Wed Oct 27, 2004 9:32 am
I tried the script on my *nux machine, and it doesn't seem to generate any output, or so it seems...?
Roman
Wed Oct 27, 2004 11:07 am
Do you have expect and tcl installed? telnet enabled on router?
this code works perfectly for me! good job Eugene! ;)
evert
Wed Oct 27, 2004 11:40 am
Yup, expect 5.37.1 & tcl 8.4.6 are present. Commenting out the log_user parameter does give the right(?) output, with
-- [Q quit|D dump|down]
on the bottom line.
Eugene
Forum Veteran
Forum Veteran
Wed Oct 27, 2004 12:50 pm
He, he:) you have too much connections in your table. Do not comment out log_user parameter. Add without-paging argument to /ip firewall connection print command instead.
Eugene
evert
Wed Oct 27, 2004 1:03 pm
That gives more! :)
123:80    tcp  time-wait   1m41s
152  A 192.168.24.140:58533  199.181.132.206:80    tcp  time-wait   1m23s
153  A 192.168.24.140:58531  199.181.132.207:80    tcp  time-wait   1m23s
154  A 192.168.24.140:58536  199.181.132.207:80    tcp  time-wait   1m23s
155  A 192.168.24.140:47582  204.74.101.1:53       udp              2m47s
156  A 192.168.24.140:55077  204.152.184.184:6277  tcp  established 4d23h54m2s
157  A 192.168.24.140:58496  206.16.0.222:80       tcp  time-wait   19s
158  A 192.168.24.140:58518  206.16.0.222:80       tcp  time-wait   1m23s
159  A 192.168.24.140:58576  207.171.166.48:80     tcp  time-wait   1m44s
160  A 192.168.24.140:58577  207.171.166.48:80     tcp  time-wait   1m44s
161  A 192.168.24.140:58578  207.171.166.48:80     tcp  time-wait   1m48s
162    192.168.24.140:47582  207.171.169.7:53      udp              13s
163  A 192.168.24.140:56123  212.97.129.35:6277    tcp  established 4d23h59m57s
164  A 192.168.24.140:58575  213.84.23.119:80      tcp  fin-wait    1m42s
165 U  192.168.24.140:58517  213.220.100.3:80      tcp  syn-sent    1m55s
166  A 192.168.24.140:58520  213.220.100.3:80      tcp  time-wait   1m58s
167    192.168.24.140:47582  216.200.69.14:53      udp              24s
168  A 192.168.24.140:47582  216.239.120.69:53     udp              2m11s
169  A 195.225.3.19:64413    213.151.155.141:6277  tcp  established 4d40m19s
170  A 204.152.184.184:58374 213.151.152.215:6277  tcp  established 4d23h59m57s
171  A 204.152.184.184:56980 213.151.155.141:6277  tcp  established 4d41m48s
172  A 212.4.33.214:13095    213.151.155.141:80    tcp  established 2d23h57m59s
173  A 213.151.152.215:1499  205.188.8.136:5190    tcp  established 4d23h59m39s
174  A 213.151.152.215:1492  205.188.11.184:5190   tcp  established 4d23h59m7s
175  A 213.151.152.215:1483  207.46.107.167:1863   tcp  established 4d23h59m40s
176  A 213.151.152.215:1488  207.46.107.169:1863   tcp  established 4d23h59m39s
177  A 213.151.152.215:1496  216.155.193.184:5050  tcp  established 4d23h59m6s
178  A 213.151.152.215:1480  217.13.3.82:1723      tcp  established 4d5h42m3s
179  A 213.151.152.215       217.13.3.82           gre              4d23h59m59s
180    213.151.153.79:1026   213.151.152.215:137   udp              2s
181  A 213.151.155.141:1319  205.188.8.138:5190    tcp  established 4d21m18s
182  A 213.151.155.141:1321  205.188.11.184:5190   tcp  established 4d21m18s
183  A 213.151.155.141:1240  207.46.106.71:1863    tcp  established 4d21m18s
184  A 213.151.155.141:1241  207.46.107.62:1863    tcp  established 4d21m18s
185  A 213.151.155.141:1248  208.245.212.67:5222   tcp  established 4d21m18s
186  A 213.151.155.141:1213  216.155.193.178:5050  tcp  established 4d21m22s
187  A 213.151.155.141:1479  217.13.2.82:1723      tcp  established 4d19m53s
188  A 213.151.155.141       217.13.3.82           gre              4d21m30s
[evert@MEULIE] >
But what I actually need is just the # of connections, as a single number... ;-)
Eugene
Forum Veteran
Forum Veteran
Wed Oct 27, 2004 1:08 pm
Revised version of the script to use with ssh. The script assumes you have no password for the account specified. Uncomment authentication line if you actually have a password.
Paging issues are fixed too
#!/usr/bin/expect
#Information gathering script for RouterOS v1.2
set timeout 20
set logn "admin"
set passwd ""
log_user 0
# Spawning quiet ssh session
eval spawn -noecho ssh -l "$logn" "$router"
#expect ".*password:" {send "$passwd\r"}
#set maximum buffer length (there are too many connections sometimes)
match_max 50000
  send "/ip firewall connection print without-paging\r"
  send_user $aa;
sleep 2
send "\r"
Eugene
Forum Veteran
Forum Veteran
Wed Oct 27, 2004 1:10 pm
I expected this :)
Eugene
Forum Veteran
Forum Veteran
Wed Oct 27, 2004 1:13 pm
$ wc -l < myscript
Maybe this way?:)
(myscript is the name of expect script)
EDIT:
Or isuue the /ip firewall connection print command with count-only argument.
evert
Wed Oct 27, 2004 1:41 pm
$ wc -l < myscript
Maybe this way?:)
This would count the number of lines of the myscript file... 8)
evert
Wed Oct 27, 2004 1:46 pm
Hmm, after that change I get no output at all from the script... weird...
Eugene
Forum Veteran
Forum Veteran
Wed Oct 27, 2004 1:54 pm
Sorry, my mistake. The correct should be:
$ ./myscript | wc -l
And working count-only snippet:
  send "/ip firewall connection print count-only\r"
expect -re "\[0-9]+" {
  set aa $expect_out(0,string);
  send_user "$aa\n";
sleep 1
send "\r"
evert
Wed Oct 27, 2004 3:05 pm
:D :D Yes! :D :D
As you can see here, that works perfectly! :)
Eugene
Forum Veteran
Forum Veteran
Wed Oct 27, 2004 3:09 pm
I'm impressed;) Can you share MRTG configuration to use script output for the benefit of others? :))
evert
Wed Oct 27, 2004 3:13 pm
Sure:
Target[conncount]: `/usr/local/bin/connection_poll`
Options[conncount]: gauge,growright,nopercent,noo
Title[conncount]: Connection count
MaxBytes[conncount]: 1000
PageTop[conncount]: <H1>Connection count</H1>
LegendO[conncount]: Connections
LegendI[conncount]: Connections
YLegend[conncount]: connections
ShortLegend[conncount]: &nbsp;connections
It's as simple as that... 8)
evert
Wed Oct 27, 2004 4:12 pm
Hmm, I'm trying to turn it into a SSH-enabled script, but there seems to be something not quite right with my version:
#!/usr/bin/expect
set timeout 20
set router "1.2.3.4"
set logn "mrtg"
set passwd "blah"
log_user 0
eval spawn -noecho ssh "$logn@$router"
      send_user "$aa\n0\n";
      sleep 1
      send "\r"
This script takes 40 seconds to finish, and always returns 192 as value... :?:
Eugene
Forum Veteran
Forum Veteran
Wed Oct 27, 2004 4:24 pm
See my ssh-enabled script above:)
evert
Tue Nov 16, 2004 10:24 am
Hi everyone!
Well, after this script worked quite well for a while, but now there is a problem surfacing on a 2.8.17 system: the SSH connections don't terminate! So after 40 mins. I have 8 open ssh connections, and then no more connections are allowed by the mrtg-username... :-/
Any suggestions anyone?
Eugene
Forum Veteran
Forum Veteran
Tue Nov 16, 2004 2:59 pm
Try to add
send "/quit\r"
at the end of the script :)
evert
Tue Nov 16, 2004 3:22 pm
Tried that. Doesn't seem to help. The problem seems to be caused by the Linux side though. a 'killall ssh' does end the active connections... 8)
Eugene
Forum Veteran
Forum Veteran
Tue Nov 16, 2004 4:26 pm
spawn -noecho killall ssh
Or use kill + pid (Expect gives you one from spawn, through I don't remember how to access it)
evert
Wed Dec 15, 2004 9:42 am
Hmm, I've come across another problem... When I run the above-created script by hand, it works like a charm, and outputs
113
0
However, when it's run from mrtg.cfg, the mrtg log gets:
2004-12-15 08:36:05 -- ERROR: Target[conncount_192.168.100.1][_IN_] ' $target->[1]{$mode} ' did not eval into defined data
2004-12-15 08:36:05 -- ERROR: Target[conncount_192.168.100.1][_OUT_] ' $target->[1]{$mode} ' did not eval into defined data
And the weird thing is that it used to work fine, until I moved part of the mrtg.cfg to a separate file, and used 'Include: mrtg-users.conf' to include it...
Any mrtg experts here? ;-)
Eugene
Forum Veteran
Forum Veteran
Wed Dec 15, 2004 1:27 pm
Printout of mrtg.cfg and mrtg-users.conf files ?
evert
Thu Dec 16, 2004 10:30 am
No needed 8)
The problem has been isolated to moving from the 'run at start/runasdaemon:yes' setting to 'run every 5 mins via cron/runasdaemon:no' setting. This because of the changing config file. And this is where it broke.
But the solution has not been found yet. I'll let you guys/gals know when/if one comes up, just in case more people run into this problem...
hhanzo
Re: Number of connections?
Tue Aug 31, 2021 2:47 pm
You can running script with GET to accomplish it..
Add script:
/system script add policy=read,write source="/ip firewall connection print count-only"
Get the script index number:
snmpwalk -v2c -cpublic 192.0.2.1 1.3.6.1.4.1.14988.1.1.8.1.1.2
SNMPv2-SMI::enterprises.14988.1.1.8.1.1.2.1 = STRING: "script1"
Run script index and return output:
snmpget -v2c -cpublic 192.0.2.1 1.3.6.1.4.1.14988.1.1.18.1.1.2.1
SNMPv2-SMI::enterprises.14988.1.1.18.1.1.2.1 = STRING: "7"
https://wiki.mikrotik.com/wiki/Manual:SNMP
Users browsing this forum: No registered users and 19 guests
