IPsec
Document revision 06-Mar-2003
This document applies to the MikroTik RouterOS V2.6
Overview
IPsec (IP Security) supports secure (encrypted) communications over IP networks.
Contents of the Manual
The following topics are covered in this manual:
Installation
Please download the ipsec-2.6.x.npk package from the MikroTik's web site, upload the package to the router and reboot.
Note that you cannot install IPsec package without SSH installed.
Use the /system package print command to see the list of installed packages.
Hardware Resource Usage
IPsec consumes a lot of CPU time, so it needs powerful processor. Intel Pentium MMX or AMD K6 suggested as minimal configuration.
How IPsec Works
Encryption
After packet is src-natted, but before putting it into interface queue, IPsec policy database is consulted to find out if packet should be encrypted. Security Policy Database (SPD) is a list of rules that have two parts:
  • Packet matching: Packet source/destination, protocol and ports (for TCP and UDP) are compared to values in policy rules, one after another
  • Action: If rule matches action specified in rule is performed:
    Each SPD rule can be associated with several Security Associations (SA) that determine packet encryption parameters (key, algorithm, SPI).
    Note that packet can only be encrypted if there is usable SA for policy rule. By setting SPD rule security "level" user can control what happens when there is no valid SA for policy rule:
  • use - if there is no valid SA, send packet unencrypted (like accept rule)
  • acquire - send packet unencrypted, but ask IKE daemon to establish new SA
  • require - drop packet, and ask IKE daemon to establish new SA.
    If packet can be encrypted, it is encrypted and sent as LOCALLY ORIGINATED packet - i.e. it is processed with "output" firewall, src-nat again and IPsec SPD again (this way one packet can be encrypted several times if encrypted packet has to be sent over encrypted tunnel itself). If packet matches the same SPD rule that it matched before, it is sent out without encrypting (to avoid encryption loops).
    Decryption
    When encrypted packet is received for local host (after dst-nat and input filter), appropriate SA to decrypt it is looked up (using packet source, destination, security protocol and SPI value). If no SA is found, packet is dropped. If SA is found, packet is decrypted. Then decrypted packets fields are compared to policy rule that SA is linked to. If packet does not match policy rule it is dropped. If packet is decrypted fine (or authenticated fine) it is "received once more" - it goes through dst-nat and routing (which finds out what to do - either forward or deliver locally) again.
    Note that before forward and input firewall chains, packet that was not decrypted on local host is compared with SPD reversing its matching rules. If SPD requires encryption (there is valid SA associated with matching SPD rule), packet is dropped. This is called incoming policy check.
    Internet Key Exchange
    The Internet Key Exchange (IKE) is a protocol that provides authenticated keying material for Internet Security Association and Key Management Protocol (ISAKMP) framework. There are other key exchange schemes that work with ISAKMP, but IKE is the most widely used one. Together they provide means for authentication of hosts and automatic management of security associations (SA).
    Most of the time IKE daemon is doing nothing. There are two possible situations when it is activated:
  • Some traffic is caught by policy that needs to provide encryption or authentication, but doesn't have any SAs. It notifies IKE daemon about that, and IKE daemon initiates connection to remote host.
  • IKE daemon responds to remote connection.
    In both cases, peers establish connection and execute 2 phases:
  • Phase 1 - peers agree on algorithms they will use in following IKE messages, authenticate. Also, keying material (used to derive keys for all SAs and to protect following ISAKMP exchanges between hosts) is generated.
  • Phase 2 - peers establish one or several SAs that will be used by IPsec to encrypt data. All SAs established by IKE daemon will have lifetime values (either limiting time, after which SA will become invalid, or amount of data that can be encrypted by this SA, or both).
    There are two lifetime values - soft and hard. When SA reaches it's soft lifetime, IKE daemon receives notice about it and starts another phase 2 exchange to replace this SA with fresh one. If SA reaches hard lifetime, it is discarded.
    Perfect Forward Secrecy (PFS) that can optionally be provided by IKE is a property of key exchanges, which for IKE means that compromising the long term phase 1 key will not allow to easily gain access to all IPsec data that is protected by SAs established through this phase 1. It means an additional keying material is generated for each phase 2.
    Generation of keying material is computationally very expensive. Use of modp8192 group can take several seconds even on very fast computer. It usually takes place once per phase 1 exchange, which happens only once between any host pair and then is kept for long time. PFS adds this expensive operation also to each phase 2 exchange.
    IKE Traffic
    To avoid problems with IKE packets hit some SPD rule and require to encrypt it with not yet established SA (that this packet perhaps is trying to establish), locally originated packets with UDP source port 500 are not processed with SPD. The same way packets with UDP destination port 500 that are to be delivered locally are not processed in incoming policy check.
    IPsec Setup
    [admin@MikroTik] ip ipsec>
                 policy
           installed-sa
              manual-sa
                   peer
      pre-shared-secret
               proposal
               counters
                 export
    Descriptions of settings:
    policy - set up security policies
    installed-sa - look at currently installed security associations
    manual-sa - templates for manual security associations
    peer - IKE peer configuration
    pre-shared-secret - to authenticate with IKE peers
    proposal - phase2 IKE proposal settings
    counters - counters
    To get IPsec to work with automatic keying you will have to configure policy, peer, pre-shared-secret and proposal entries. For manual keying you will have to configure policy and manual-sa entries.
    Policy Settings
    To define new policy, use /ip ipsec policy add command:
    [admin@MikroTik] ip ipsec policy> add sa-src-address=10.0.0.205 sa-dst-address=10.0.0.201 \
    \... action=encrypt
    [admin@MikroTik] ip ipsec policy> print
      0   src-address=10.0.0.205/32:any dst-address=10.0.0.201/32:any
          protocol=all action=encrypt level=require ipsec-protocols=esp tunnel=no
          sa-src-address=10.0.0.205 sa-dst-address=10.0.0.201 proposal=default
          manual-sa=none dont-fragment=clear
    Argument description:
    src-address - Source IP address. Can be in the form address/mask:ports
    dst-address - Destination IP address. Can be in the form address/mask:ports
    protocol - name or number of protocol action - What to do with packet that matches policy. Choices are: dont-fragment - default value works OK. It is good to have dont-fragment cleared because encrypted packets are always bigger than original and thus they may need fragmentation.
    tunnel - yes if you want to use tunnel mode. In tunnel mode all packets are IPIP encapsulated, and their new IP header src and dst are set to sa-src and sa-dst values of this policy. If you don't use tunnel mode (i.e. you use transport mode), then only packets whose source and destination is the same as sa-src and sa-dst can be processed by this policy. Transport mode can only work with packets that originate at and are destined for IPsec peers (hosts that established security associations). To encrypt traffic between networks (or network and host) you have to use tunnel mode.
    ipsec-protocols - One of ah, esp, ah,esp. Specifies what combination of Authentication Header and Encapsulating Security Payload protocols you want to apply to matched traffic. AH is applied after ESP, and in case of tunnel mode ESP will be applied in tunnel mode and AH - in transport mode.
    level - What to do if some of the SAs for this policy cannot be found: sa-src-address - SA source
    sa-dst-address - SA destination
    manual-sa - Name of manual-sa template that will be used to create SAs for this policy, or none if you don't want to set up any manual keys.
    proposal - Name of proposal info that will be sent by IKE daemon to establish SAs for this policy.
    If you are using IKE to establish SAs automatically, then policies on both routers must be exactly matching, i.e. src-address=1.2.3.0/27 on one router and dst-address=1.2.3.0/28 on another won't work. src values on one router MUST be equal to dst values on the other one, and vice versa.
    Statistics can be printed out using print stats command:
    [admin@MikroTik] ip ipsec policy> print stats
          protocol=all ph2-state=no-phase2 in-accepted=0 in-dropped=0
          out-accepted=0 out-dropped=0 encrypted=0 not-encrypted=0 decrypted=0
          not-decrypted=0
    Description of the printout:
    ph2-state - progress of key establishing. 'expired' means there are some leftovers from previous phase2, and is similar to 'no-phase2', which means nothing has happened. 'established' means SAs are in place and everything should be working. Anything else falls between these last two states.
    in-accepted - how many incoming packets were passed through by policy without attempting decryption.
    in-dropped - how many incoming packets were dropped by policy without attempting decryption.
    out-accepted - how many outgoing packets were passed through by policy without encryption.
    out-dropped - how many outgoing packets were dropped by policy without attempting encryption.
    encrypted - how many outgoing packets were encrypted and passed on successfully.
    not-encrypted - how many outgoing packets policy attempted to encrypt, but discarded for any reason.
    decrypted - how many incoming packets policy decrypted and passed on successfully.
    not-decrypted - how many incoming packets policy tried to decrypt, but discarded for any reason.
    See global counters for more specific conditions.
    Peer
    Peer configuration settings are used to establish connections between IKE daemons (phase 1 configuration). This connection then will be used to negotiate keys and algorithms for SAs. These parameters won't affect the established SAs in any way. To define new peer configuration, use /ip ipsec peer add command:
    [admin@MikroTik] ip ipsec peer> add address=10.0.0.201
    [admin@MikroTik] ip ipsec peer> print
    Flags: X - disabled
      0   address=10.0.0.201:500 exchange-mode=main send-initial-contact=yes
          proposal-check=strict hash-algorithm=md5 enc-algorithm=3des
          dh-group=modp1024
    address - address of the remote peer
    dh-group - Diffie-Hellman (DH) key exchange protocol allows two parties without any initial shared secret to create one. This value defines cipher strength. Allowed values: modp768, modp1024, modp1536, modp2048, modp3072, modp4096, modp8192. First three (768, 1024 and 1536) are standard, others might be incompatible with similarly named groups in other implementations
    enc-algorithm - Encryption algorithm. Valid algorithms are: des, 3des, aes-128, aes-192 and aes-256 in strength (and computation time) increasing order
    exchange-mode - Valid values are: main, aggressive or base. See RFC 2408 for an overview of ISAKMP phase 1 exchange modes. Currently only main mode is tested
    hash-algorithm - Hashing algorithm. Valid algorithms are md5 and sha in strength (and computation time) increasing order
    proposal-check - Lifetime check logic. This is for phase 2 lifetimes (you cannot configure lifetimes for phase 1 proposals yet). One of: send-initial-contact - yes
    Note that both peers MUST have the same encryption and authentication algorithms, dh-group and exchange-mode. Some legacy hardware may support only DES and MD5.
    Statistics can be printed out using print stats command.
    For not yet established connections:
    [admin@MikroTik] ip ipsec peer> print stats
    Flags: X - disabled
          dh-group=modp1024 ph1-state=no-phase1
    For running connection:
    Flags: X - disabled
          dh-group=modp1024 ph1-state=established ph1-side=initiator
          ph1-established=nov/19/2008 17:13:24 ph2-active=0 ph2-total=1
    ph1-state - state of phase 1 negotiation with this peer. established is the normal working state
    ph1-side - who spoke first. initiator means that phase 1 negotiation was started by this router. responder - by peer
    ph1-established - when current phase 1 between router and peer was established
    ph2-active - how many phase 2 negotiations with this peer are currently taking place
    ph2-total - how many phase 2 negotiations with this peer took place
    Pre-shared-secret
    For IKE peers to know each other they must have same pre-shared-secret configuration. It's kind of like passwords. So if there are two routers: 10.0.0.205 and 10.0.0.201, then on the first (10.0.0.205) it should look like this:
    [admin@MikroTik] ip ipsec pre-shared-secret> print
    Flags: X - disabled
      #   ADDRESS         SECRET
      0   10.0.0.201      gwejimezyfopmekun
    And on the second (10.0.0.201) - like this:
    Flags: X - disabled
      #   ADDRESS         SECRET
      0   10.0.0.205      gwejimezyfopmekun
    Parameter description:
    address - address of remote peer
    ident-string - identity string of remote peer
    secret - secret string. If it starts with '0x', it is parsed as a hexadecimal value
    Manual SA
    To add manual-sa entry, use ip ipsec manual-sa add command:
    [admin@MikroTik] ip ipsec manual-sa> add ah-key=A0/0A
    [admin@MikroTik] ip ipsec manual-sa> print
      0   name="sa1" ah-algorithm=null esp-auth-algorithm=null
          esp-enc-algorithm=null ah-key=A0/0A esp-auth-key="" esp-enc-key=""
          ah-spi=100 esp-spi=100
    Command parameters are:
    ah-algorithm - Authentication Header encryption algorithm, one of the following: esp-auth-algorithm - Encapsulating Security Payload authentication encryption algorithm, one of the following: esp-auth-algorithm - Encapsulating Security Payload encryption algorithm, one of the following: ah-key - incoming-authentication-key/outgoing-authentication-key
    ah-spi - incoming-SA-SPI/outgoing-SA-SPI, in hexadecimal. May be equal
    esp-auth-key - incoming-authentication-key/outgoing-authentication-key
    esp-enc-key - incoming-encryption-key/outgoing-encryption-key
    esp-spi - incoming-SA-SPI/outgoing-SA-SPI, in hexadecimal. May be equal
    name - name of item for reference from policies
    Note that incoming SPI numbers on one router must match outgoing SPI numbers on another, and vice versa. Same for keys.
    You can reference same manual-sa template from several policies, because actual SAs are inserted based on info in policies (AH, ESP) as well as in this template, as well as in key config. Also, each SA is distinguished by its source (sa-src), destination (sa-dst), protocol (AH or ESP), SPI and direction.
    Proposal
    To add proposal, use ip ipsec proposal add command. There is a default proposal:
    [admin@MikroTik] ip ipsec proposal> print
    Flags: X - disabled
      0   name="default" auth-algorithms=sha1 enc-algorithms=3des lifetime=30m
          lifebytes=0 pfs-group=modp1024
    auth-algorithms - allowed algorithms for authorization: enc-algorithms - allowed algorithms and key lengths to use for SAs that will be acquired from IKE daemon by policy that references this proposal (3des, aes-128, aes-192, aes-256, des, null) lifebytes - how many bytes to encrypt using SA before throwing it out and making new one. 0 means SA won't expire based on byte count (default)
    lifetime - how long to use SA before throwing it out. See also proposal-check in peer config
    name - name of proposal for referencing it from policy
    pfs-group - Diffie-Helman group used for Perfect Forward Secrecy
    Proposals on both peers must (at least partially) match. The more they match the better.
    Installed SA
    Prints a lot of information about each installed SA (including keys):
    [admin@MikroTik] ip ipsec installed-sa> print
    Flags: A - AH, E - ESP, P - pfs, M - manual
      0 E   spi=21237B07 direction=out src-address=10.0.0.204
            dst-address=10.0.0.201 auth-algorithm=sha1 enc-algorithm=3des
            replay=4 state=mature
            auth-key="3c1f4a3f5d2014e565f9f3fb671bab89056febb5"
            enc-key="725d43ed2742530a257d19dd36702259ea7a50060aa760a3"
            add-lifetime=24m/30m use-lifetime=0s/0s lifebytes=0/0
            current-addtime=nov/24/2008 14:28:42
            current-usetime=jan/01/1970 00:00:00 current-bytes=0
      1 E   spi=FAACF20D direction=in src-address=10.0.0.201
            dst-address=10.0.0.204 auth-algorithm=sha1 enc-algorithm=3des
            auth-key="acb0c8c3dc81f3ff5f92cbc15c49c7a710f9efa5"
            enc-key="a50c04b44904c07009c3e218760f3827493579172b29bcfd"
    spi - SPI value of SA, in hexadecimal
    replay - size of replay window, in bytes
    state - larval, mature, dying or dead
    auth-algorithm - none, md5 or sha1
    enc-algorithm - none, des, 3des, aes
    src-address - source of SA from policy configuration
    dst-address - destination of SA from policy configuration
    auth-key - authentication key, as hex string
    enc-key - encryption key, as hex string (only used by ESP SAs)
    direction - in or out
    current-addtime - time when this SA was installed
    current-usetime - time when this SA was first used
    current-bytes - amount of data processed by this SA's crypto algorithms
    add-lifetime - expiration time counted from installation of SA. soft/hard
    use-lifetime - expiration time counter from the first use of SA. soft/hard>
    lifebytes - expiration threshold for amount of processed data. soft/hard
    Counters
    Prints miscellaneous counters:
    [admin@MikroTik] ip ipsec> counters print
                        out-accept: 2298
                          out-drop: 0
                       out-encrypt: 4
                         in-accept: 3497
                           in-drop: 0
                      in-decrypted: 4
                  in-accept-isakmp: 20
                 out-accept-isakmp: 12
        in-drop-encrypted-expected: 0
    out-accept - how many outgoing packets were matched by 'accept' policy (including the default "accept all" case)
    out-accept-isakmp - how many locally originated UDP packets on source port 500 (which is how ISAKMP packets look) were let through without policy matching
    out-drop - how many outgoing packets were matched by drop policy (or encrypt policy with level=require that doesn't have all SAs)
    out-encrypt - how many outgoing packets were encrypted successfully
    in-accept - how many incoming packets were matched by accept policy
    in-accept-isakmp - how many incoming UDP packets on port 500 were let through without policy matching
    in-drop - how many incoming packets matched drop policy. (or encrypt policy with level=require that didn't have all SAs)
    in-decrypted - how many incoming packets were successfully decrypted
    in-drop-encrypted-expected - how many incoming packets were matched by encrypt policy and dropped because they were not encrypted
    Application examples
    IPsec setup between two RourerOS routers
    MT-to-MT
    Minimal config example for transport mode ESP with automatic keying on Router 1:
    ip ipsec policy add sa-src=1.0.0.1 sa-dst=1.0.0.2 action=encrypt
    ip ipsec peer add address=1.0.0.2
    ip ipsec pre-shared-secret add address=1.0.0.2 secret="roberkenon"
    And for Router 2:
    ip ipsec policy add sa-src=1.0.0.2 sa-dst=1.0.0.1 action=encrypt
    ip ipsec peer add address=1.0.0.1
    ip ipsec pre-shared-secret add address=1.0.0.1 secret="roberkenon"
    Minimal config example for tunnel mode AH with manual keying on Router 1:
    ip ipsec manual-sa add name=ah-sa1 ah-spi=0x101/0x100 ah-key=abcfed
    ip ipsec policy add src-address=10.1.0.0/24 dst-address=10.2.0.0/24 \
       action=encrypt ipsec-protocols=ah tunnel=yes sa-src=1.0.0.1 sa-dst=1.0.0.2 \
       manual-sa=ah-sa1
    And for Router 2:
    ip ipsec manual-sa add name=ah-sa1 ah-spi=0x100/0x101 ah-key=abcfed
    ip ipsec policy add src-address=10.2.0.0/24 dst-address=10.1.0.0/24 \
       action=encrypt ipsec-protocols=ah tunnel=yes sa-src=1.0.0.2 sa-dst=1.0.0.1 \
       manual-sa=ah-sa1
    IPsec Setup for Routing Between two Masquerading MikroTik Routers
    MT-to-MT
    On Router1:
  • Add accept and masquerading rules in SRC-NAT:
    /ip firewall src-nat add src-address=10.1.0.0/24 dst-address=10.2.0.0/24
    /ip firewall src-nat add out-interface=public action=masq
  • Configure IPsec:
    /ip ipsec policy add src-address=10.1.0.0/24 dst-address=10.2.0.0/24 \
        action=encrypt tunnel=yes sa-src-address=1.0.0.1 sa-dst-address=1.0.0.2
    /ip ipsec peer add address=1.0.0.2 exchange-mode=aggressive
    /ip ipsec pre-shared-secret add address=1.0.0.2 secret="sviestapika"
    On Router2:
    /ip firewall src-nat add src-address=10.2.0.0/24 dst-address=10.1.0.0/24
  • Configure IPsec:
    /ip ipsec policy add src-address=10.2.0.0/24 dst-address=10.1.0.0/24 \
    action=encrypt tunnel=yes sa-src-address=1.0.0.2 sa-dst-address=1.0.0.1
    /ip ipsec peer add address=1.0.0.1 exchange-mode=aggressive
    /ip ipsec pre-shared-secret add address=1.0.0.1 secret="sviestapika"
    IPsec Setup Between MikroTik and CISCO Routers
    MT-to-CISCO
    Must configure IPsec encryption for traffic between 10.0.0.0/24 and 10.0.2.0/24 subnets.
    Configuring RouterOS
    Add encryption proposal (phase2 proposal - settings that will be used to encrypt actual data), we will use DES to encrypt data and SHA1 to authenticate:
    [admin@MikroTik] ip ipsec proposal> add name=to_cisco pfs-group=none
    algorithms=enc-des,auth-sha1
    Add peer (with phase1 configuration parameters), DES and SHA1 will be used to protect IKE traffic:
    [admin@MikroTik] ip ipsec peer> add address=10.0.1.2 enc-algorithm=des
    auth-method=pre-shared-key hash-algorithm=sha dh-group=modp1024
    Add preshared secret to use when talking to Cisco:
    [admin@MikroTik] ip ipsec pre-shared-secret> add secret=test_key
    address=10.0.1.2
    Add policy rule that matches traffic between subnets and requires encryption with ESP in tunnel mode:
    [admin@MikroTik] ip ipsec policy> add src-address=10.0.0.0/24
    dst-address=10.0.2.0/24 protocol=all action=encrypt ipsec-protocols=esp
    level=require tunnel=yes sa-src=10.0.1.1 sa-dst=10.0.1.2 proposal=to_cisco
    Configuring Cisco
    Parts from Cisco configuration with comments follow...
    ! Configure ISAKMP policy (phase1 config, must match configuration
    ! of "/ip ipsec peer" on RouterOS). Note that DES is default (and only)
    ! encryption algorithm on this Cisco. SHA1 is default authentication
    ! algorithm
    crypto isakmp policy 10
     authentication pre-share
     group 2
    ! Add preshared key to be used when talking to RouterOS
    crypto isakmp key test_key address 10.0.1.1
    ! Create IPsec transform set - transformations that should be applied to
    ! traffic - ESP encryption with DES and ESP authentication with SHA1
    ! This must match "/ip ipsec proposal"
    crypto ipsec transform-set myset esp-des esp-sha-hmac
    ! Create access list that matches traffic that should be encrypted
    access-list 101 permit ip 10.0.2.0 0.0.0.255 10.0.0.0 0.0.0.255
    ! Create crypto map that will use transform set "myset", use peer 10.0.1.1
    ! to establish SAs and encapsulate traffic and use access-list 101 to
    ! match traffic that should be encrypted
    crypto map mymap 10 ipsec-isakmp
     set peer 10.0.1.1
     set transform-set myset
     match address 101
    ! And finally apply crypto map to serial interface:
    interface Serial1
     crypto map mymap
    Testing
    After this simply ping from some host in one network to some host in other network - after some time (~10sec) replies should start coming back because SAs are established and data is being encrypted.
    On RouterOS we can see installed SAs:
      0 E   spi=9437482 direction=out src-address=10.0.1.1
            dst-address=10.0.1.2 auth-algorithm=sha1 enc-algorithm=des
            auth-key="9cf2123b8b5add950e3e67b9eac79421d406aa09"
            enc-key="ffe7ec65b7a385c3" add-lifetime=24m/30m use-lifetime=0s/0s
            lifebytes=0/0 current-addtime=jul/12/2002 16:13:21
            current-usetime=jul/12/2002 16:13:21 current-bytes=71896
      1 E   spi=319317260 direction=in src-address=10.0.1.2
            dst-address=10.0.1.1 auth-algorithm=sha1 enc-algorithm=des
            auth-key="7575f5624914dd312839694db2622a318030bc3b"
            enc-key="633593f809c9d6af" add-lifetime=24m/30m use-lifetime=0s/0s
            current-usetime=jul/12/2002 16:13:21 current-bytes=0
    And on Cisco:
    interface: Serial1
        Crypto map tag: mymap, local addr. 10.0.1.2
       local  ident (addr/mask/prot/port): (10.0.2.0/255.255.255.0/0/0)
       remote ident (addr/mask/prot/port): (10.0.0.0/255.255.255.0/0/0)
       current_peer: 10.0.1.1
         PERMIT, flags={origin_is_acl,}
        #pkts encaps: 1810, #pkts encrypt: 1810, #pkts digest 1810
        #pkts decaps: 1861, #pkts decrypt: 1861, #pkts verify 1861
        #pkts compressed: 0, #pkts decompressed: 0
        #pkts not compressed: 0, #pkts compr. failed: 0, #pkts decompress failed: 0
        #send errors 0, #recv errors 0
         local crypto endpt.: 10.0.1.2, remote crypto endpt.: 10.0.1.1
         path mtu 1500, media mtu 1500
         current outbound spi: 1308650C
         inbound esp sas:
          spi: 0x90012A(9437482)
            transform: esp-des esp-sha-hmac ,
            in use settings ={Tunnel, }
            slot: 0, conn id: 2000, flow_id: 1, crypto map: mymap
            sa timing: remaining key lifetime (k/sec): (4607891/1034)
            IV size: 8 bytes
            replay detection support: Y
         inbound ah sas:
         inbound pcp sas:
         outbound esp sas:
          spi: 0x1308650C(319317260)
            slot: 0, conn id: 2001, flow_id: 2, crypto map: mymap
            sa timing: remaining key lifetime (k/sec): (4607893/1034)
            IV size: 8 bytes
         outbound ah sas:
         outbound pcp sas:
    IPsec setup between RouterOS router and Windows SonicWall Client
    IPSec setup of RouterOS router as a Security Gateway for SonicWALL VPN client
    MT-to-SW
    Configuring remote access of 1.1.1.0 network through 10.0.0.204 RouterOS router
    1. Add peer configuration. Use Triple-DES and SHA-1 algorithms to protect phase 1 traffic. Set "proposal-check" to "obey" to allow remote client to connect even if lifetime and pfs settings in its proposal don't match ours.
      / ip ipsec peer add address=10.0.0.81:500 exchange-mode=main \
      send-initial-contact=no proposal-check=obey hash-algorithm=sha \
      enc-algorithm=3des dh-group=modp1024
    2. Add pre-shared secret to identify remote client.
      / ip ipsec pre-shared-secret add address=10.0.0.81 secret="********"
    3. Add encryption proposal. Use MD5, DES and Diffie-Hellman Group 1 for Perfect Forward Secrecy.
      / ip ipsec proposal add name=sw-client auth-algorithms=md5 enc-algorithms=des \
      lifetime=30m pfs-group=modp768
    4. Add policy rule that matches traffic between remote client and 1.1.1.0/24 network, use ESP in tunnel mode to encript all data.
      / ip ipsec policy add src-address=1.1.1.0/24 dst-address=10.0.0.81/32 \
      action=encrypt ipsec-protocols=esp tunnel=yes sa-src-address=10.0.0.204 \
      sa-dst-address=10.0.0.81 proposal=sw-client
    Configuring SonicWALL
    Here you create IPSec policy that should match all traffic between 10.0.0.81 host and 1.1.1.0/24 network. You also specify the address of remote IPSec peer:
    "Connection Security": select "Secure"
    in "Remote Party Identity And Addressing" box:
      "ID Type": select "IP Subnet"
      "Subnet": enter "1.1.1.0"
      "Mask": enter "255.255.255.0"
      check "Connect using", select "Secure Gateway Tunnel"
      "ID Type": select "IP Address", enter below "10.0.0.204"
    Configure pre-shared key, select correct interface to connect to 10.0.0.204 router with the proper address 10.0.0.81:
    My Identity
    in "My Identity" box:
      "Select Certificate": select "None"
      click "Pre-Shared Key"
    "Pre-Shared Key" pops up:
    Pre-Shared Key
        click "Enter Key"
        type ********, click "OK"
    in "Internet Interface" box:
      "Name": select interface that is connected to 10.0.0.0/24 network
      "IP Addr": check that it shows 10.0.0.81
    Configure phase 1 setting to use same algorithms as on RouterOS side:
    Security Policy
    "Select Phase 1 Negotiation Mode": select "Main Mode"
    check "Enable Perfect Forward Secrecy (PFS)"
    "PFS Key Group": select "Diffie-Hellman Group 1"
    clear "Enable Replay Detection"
    Authentication (Phase 1) Proposal 1
    "Authentication Method": select "Pre-Shared Key"
    in "Encryption and Data Integrity Algorithms" box:
      "Encrypt Alg": select "Triple DES"
      "Hash Alg": select "SHA-1"
      "SA Life": select "Unspecified"
    "Key Group": select "Diffie-Hellman Group 2" (this is called "modp1024"
    in RouterOS)
    Configure phase 2 settings:
    Key Exchange (Phase 2) Proposal 1
    in "IPSec Protocols" box:
      "SA Life": select "Seconds", enter "1800" in "Seconds" field
      "Compression": select "None"
      check "Encapsulation Protocol (ESP)"
        "Encrypt Alg": select "DES"
        "Hash Alg": select "MD5"
        "Encapsulation": select "Tunnel"
      clear "Authentication Protocol (AH)"
    click "Save" (on the toolbar)
    Testing
    Try accessing some host on 1.1.1.0/24 network from 10.0.0.81 box. After some time IPSec tunnel will be established and data will start to pass through.
    On RouterOS side you can see the statistics for established SAs:
    [admin@xxx] ip ipsec installed-sa> print
      0 E   spi=3C3C7A8D direction=out src-address=10.0.0.204
            dst-address=10.0.0.81 auth-algorithm=md5 enc-algorithm=des replay=4
            state=mature auth-key="5697ee9fe98867005ac057e1b62a6c3b"
            enc-key="7b992840ea30b180" add-lifetime=24m/30m use-lifetime=0s/0s
            lifebytes=0/0 current-addtime=nov/26/2002 09:33:47
            current-usetime=nov/26/2002 09:33:53 current-bytes=896
      1 E   spi=A472A105 direction=in src-address=10.0.0.81
            dst-address=10.0.0.204 auth-algorithm=md5 enc-algorithm=des replay=4
            state=mature auth-key="70655b51846308f68ce964d90b5580cd"
            enc-key="a3623a16f6bef13d" add-lifetime=24m/30m use-lifetime=0s/0s
            current-usetime=nov/26/2002 09:33:53 current-bytes=0
    On SonicWall side you can view logs and connection statistics by right-clicking SonicWALL tray icon and choosing apropriate options:
    © Copyright 1999-2003, MikroTik
