IP packet flow through the router is given in the following diagram:
IP Firewall Configuration
The IP firewall management can be accessed under the /ip firewall menu.
Firewall can be managed through the WinBox Console as well.
Go to IP Firewall and select the desired chain.
Press the 'List' button to access the rules of the selected chain.
IP Firewall Common Arguments
The common arguments used in the firewall rules are:
action - Action to undertake if the packet matches the rule (see below). The choice of the available action is different for firewall filter, mangle and NAT rules.
mark-flow - (MANGLE only) Flow mark string.
dst-address - Destination IP address. Can be in the form address/mask:ports, where mask is number of bits in the subnet, and ports is one port, or range of ports, e.g., x.x.x.x/32:80-81
dst-netmask - Destination netmask in decimal form x.x.x.x
dst-port - Destination port number or range (0-65535). 0 means all ports 1-65535.
icmp-options - "any:any". ICMP options.
out-interface - interface the packet is leaving the router. If the default value 'all' is used, it may include the local loopback interface for packets with destination to the router.
limit-burst - allowed burst regarding the limit-count/limit-time
limit-count - how many times to use the rule during the limit-time period
limit-time - time interval, used in limit-count
protocol - Protocol (all / egp / ggp / icmp / igmp / ip-encap / ip-sec / tcp / udp). all cannot be used, if you want to specify ports.
src-address - Source IP address. Can be in the form address/mask:ports, where mask is number of bits in the subnet, and ports is one port, or range of ports, e.g., x.x.x.x/32:80-81
src-mac-address - host's MAC address the packet has been received from.
src-netmask - Source netmask in decimal form x.x.x.x
src-port - Source port number or range (0-65535). 0 means all ports 1-65535.
in-interface - interface the packet has entered the router through. If the default value 'all' is used, it may include the local loopback interface for packets originated from the router.
tcp-mss - (MANGLE only) The new TCP Maximum Segment Size (MSS) value, MTU minus 40, or dont-change.
tcp-options - ( all / syn-only / non-syn-only ). non-syn-only is for all other options than syn-only.
connection-state - (any / established / invalid / new / related). The connection state.
flow - Flow mark to match. Only packets marked in the MANGLE would be matched.
jump-target - Name of the target chain, if the action=jump is used.
log - Log the action ( yes / no ).
To view the byte and packet counters, use commands print bytes, print packets. To reset the counters, use the command reset-counters.
If the packet matches the criteria of the rule, then the performed ACTION can be:
Logging the Firewall Actions
To enable logging of the firewall actions you should set the value
of the rule argument log to yes. Also, the logging facility should be enabled
for firewall logs:
[admin@MikroTik] system logging facility> set Firewall-Log logging=local [admin@MikroTik] system logging facility> print # FACILITY LOGGING PREFIX REMOTE-ADDRESS REMOTE-PORT 0 Firewall-Log local 1 PPP-Account none 2 PPP-Info none 3 PPP-Error none 4 System-Info local 5 System-Error local 6 System-Warning local 7 Prism-Info local [admin@MikroTik] system logging facility>
You can send UDP log messages to a remote syslog host by specifying the remote address and port (usually 514). Local logs can be viewed using the /log print command:
[admin@MikroTik] > log print detail without-paging
time=feb/24/2002 19:37:08
message=router->REJECT, in:ether1, out:(local), src-mac \
00:30:85:95:67:2b, prot TCP (SYN), \
213.67.20.9:4164->195.13.162.195:21, len 60
(The format of the log is:
DATE TIME Chain -> ACTION, in:interface, out:interface, \
src-mac ADDRESS, protocol (protocol option), \
src-address:port->dst-address:port, packet_length )
Marking the Packets (Mangle) and Changing the MSS
Packets entering the router can be marked for further processing them against the rules of
firewall chains, source or destination NAT rules, as well as for applying queuing to them.
Use the /ip firewall mangle to manage the packet marking. Specify the value for the
'mark-flow' argument and use 'action=passthrough', for example:
[admin@MikroTik] ip firewall mangle> add action=passthrough mark-flow=abc-all
[admin@MikroTik] ip firewall mangle> print
0 src-address=0.0.0.0/0:0-65535 in-interface=all
dst-address=0.0.0.0/0:0-65535 protocol=all tcp-options=any
icmp-options=any:any flow="" src-mac-address=00:00:00:00:00:00
limit-count=0 limit-burst=0 limit-time=0s action=passthrough
mark-flow=abc-all tcp-mss=dont-change
Note, that the packets originated from the router cannot be mangled!
To change the TCP Maximum Segment Size (MSS), set the 'tcp-mss' argument to a value which is your desired MTU value less 40, for example, if your connection MTU is 1500, you can set 'tcp-mss=1460' or lower. The MSS can be set only for TCP SYN packets.
For example, if you have encrypted PPPoE link with MTU=1492, set the mangle rule as follows:
[admin@MikroTik] ip firewall mangle> add protocol=tcp tcp-options=syn-only\
\.. action=passthrough tcp-mss=1448
dst-address=0.0.0.0/0:0-65535 protocol=tcp tcp-options=syn-only
mark-flow="" tcp-mss=1448
Firewall Chains
The firewall filtering rules are grouped together in chains.
It is very advantageous, if packets can be matched against one common criterion in one chain,
and then passed over for processing against some other common criteria to another chain.
Let us assume that, for example, packets must be matched against the IP addresses and ports.
Then matching against the IP addresses can be done in one chain without specifying the protocol ports.
Matching against the protocol ports can be done in a separate chain without specifying the IP addresses.
The Input Chain is used to process packets entering the router through one of the interfaces with the destination of the router. Packets passing through the router are not processed against the rules of the input chain.
The Forward Chain is used to process packets passing through the router.
The Output Chain is used to process originated from the router and leaving it through one of the interfaces. Packets passing through the router are not processed against the rules of the output chain.
Note, that the packets passing through the router are not processed against the rules of neither the input, nor output chains!When processing a chain, rules are taken from the chain in the order they are listed there from the top to the bottom. If it matches the criteria of the rule, then the specified action is performed on the packet, and no more rules are processed in that chain. If the packet has not matched any rule within the chain, then the default policy action of the chain is performed.
The list of currently defined chains can be viewed using the /ip firewall print command:
[admin@MikroTik] ip firewall> print # NAME POLICY 0 input accept 1 forward accept 2 output accept [admin@MikroTik] ip firewall>
These three chains cannot be deleted. The available policy actions are:
Note! Be careful about changing the default policy action to these chains! You may lose the connection to the router, if you change the policy to drop, and there are no rules in the chain, that allow connection to the router.
Usually packets should be matched against several criteria. More general filtering rules can be grouped together in a separate chain. To process the rules of additional chains, the 'jump' action should be used to this chain from another chain.
To add a new chain, use the /ip firewall add command:
[admin@MikroTik] ip firewall> add name=router [admin@MikroTik] ip firewall> print # NAME POLICY 0 input accept 1 forward accept 2 output accept 3 router none [admin@MikroTik] ip firewall>
The policy of user added chains is 'none', and it cannot be changed.
Chains cannot be removed, if they contain rules (are not empty).
Firewall Rules
Management of the firewall rules can be accessed by selecting the desired chain.
If you use the WinBox console, select the desired chain and then press the 'List'
button on the toolbar to open the window with the rules.
In the terminal console, use the /ip firewall rule command with the argument value
that specifies a chain, for example:
[admin@MikroTik] ip firewall> rule input [admin@MikroTik] ip firewall rule input>
To add a rule, use the add command, for example:
[admin@MikroTik] ip firewall rule input> add dst-port=8080 protocol=tcp action=reject
[admin@MikroTik] ip firewall rule input> print
dst-address=0.0.0.0/0:8080 out-interface=all protocol=tcp
icmp-options=any:any tcp-options=any connection-state=any flow=""
src-mac-address=00:00:00:00:00:00 limit-count=0 limit-burst=0
limit-time=0s action=reject log=no
Here, the available values for the argument action are: accept, drop, jump, passthrough, reject, return. See the argument description above.
Masquerading and Source NAT
Masquerading is a firewall function that can be used to 'hide' private networks
behind one external IP address of the router. For example, masquerading is useful,
if you want to access the ISP's network and the Internet
appearing as all requests coming from one single IP address given to you by the ISP.
The masquerading will change the source IP address and port of the packets
originated from the private network to the external address of the router,
when the packet is routed through it.
Masquerading helps to ensure security since each outgoing or incoming request must go through a translation process that also offers the opportunity to qualify or authenticate the request or match it to a previous request. Masquerading also conserves the number of global IP addresses required and it lets the whole network use a single IP address in its communication with the world.
To use masquerading, a source NAT rule with action masquerade should be added to the src-nat rule set:
[admin@MikroTik] ip firewall src-nat> add src-address=10.5.91.0/24:0-65535 \
\... out-interface=ether1 action=masquerade
[admin@MikroTik] ip firewall src-nat> print
0 src-address=10.5.91.0/24:0-65535 dst-address=0.0.0.0/0:0-65535
out-interface=ether1 protocol=all icmp-options=any:any flow=""
limit-count=0 limit-burst=0 limit-time=0s action=masquerade
to-src-address=0.0.0.0 to-src-port=0-65535
If the packet matches the 'masquerading' rule, then the router opens a connection to the destination, and sends out a modified packet with its own address and a port allocated for this connection. The router keeps track about masqueraded connections and performs the 'demasquerading' of packets, which arrive for the opened connections. For filtering purposes, you may want to specify 'the to-src-ports' argument value, say, to 60000-65535.
If you want to change the source address:port to specific adress:port, use the action=nat instead of action=masquerade:
[admib@MikroTik] ip firewall src-nat> add src-address=192.168.0.1/32 \
\... out-interface=ether1 action=nat to-src-address=10.0.0.217
0 src-address=192.168.0.1/32:0-65535 dst-address=0.0.0.0/0:0-65535
limit-count=0 limit-burst=0 limit-time=0s action=nat
to-src-address=10.0.0.217 to-src-port=0-65535
Here, the
src-address - can be IP host's address, for example, 192.168.0.1/32, or network address 192.168.0.0/24
to-src-address - can be one address, or a range, say 10.0.0.217-10.0.0.219. The addresses should be added to the router's interface, or should be routed to it from the gateway router.
The source nat can masquerade several private networks, and use individual to-src-address for
each of them.
Redirection and Destination NAT
Redirection and destination NAT should be used when you need to give access to services located on a private network from the outside world. To add a destination NAT rule that gives access to the http server 192.168.0.4 on the local network via external address 10.0.0.217, use the following command:
[admin@MikroTik] ip firewall dst-nat>add action=nat protocol=tcp \
\... dst-address=10.0.0.217/32:80 to-dst-address=192.168.0.4
[admin@MikroTik] ip firewall dst-nat> print
dst-address=10.0.0.217/32:80 protocol=tcp icmp-options=any:any flow=""
limit-time=0s action=nat to-dst-address=192.168.0.4 to-dst-port=0-65535
Here, if you want to redirect to the router's local address, use 'action=redirect' and do not specify the to-dst-address.
When packet is dst-natted (no matter - action=nat or action=redirect), dst address is changed. Information about translation of addresses (including original dst address) is kept in router's internal tables. Transparent web proxy working on router (when web requests get redirected to proxy port on router) can access this information from internal tables and get address of web server from them. If you are dst-natting to some different proxy server, it has no way to find web server's address from IP header (because dst address of IP packet that previously was address of web server has changed to address of proxy server). Starting from HTTP/1.1 there is special header in HTTP request which tells web server address, so proxy server can use it, instead of dst address of IP packet. If there is no such header (older HTTP version on client), proxy server can not determine web server address and therefore can not work.
It means, that it is impossible to correctly transparently redirect HTTP traffic from router to some
other transparent-proxy box. Only correct way is to add transparent proxy on the router itself, and
configure it so that your "real" proxy is parent-proxy. In this situation your "real" proxy does not
have to be transparent any more, as proxy on router will be transparent and will forward proxy-style
requests (according to standard; these requests include all necessary information about web server)
to "real" proxy.
Connection Tracking
Connections through the router and their states can be monitored at 'ip firewall connection', for example:
[admin@MikroTik] ip firewall connection> print Flags: U - unreplied, A - assured # SRC-ADDRESS DST-ADDRESS PR.. TCP-STATE TIMEOUT 0 A 10.5.91.205:1361 10.5.0.23:22 tcp established 4d23h59m55s 1 A 10.5.91.205:1389 10.5.5.2:22 tcp established 4d23h59m21s 2 A 10.5.91.205:1373 10.5.91.254:3986 tcp established 4d23h59m56s 3 A 10.5.91.205:1377 159.148.172.3:23 tcp established 4d23h35m14s 4 A 80.232.241.3:1514 159.148.172.204:1723 tcp established 4d23h59m53s 5 159.148.172.204 80.232.241.3 47 9m21s [admin@MikroTik] ip firewall connection>
Connection timeouts are as follows:
Read about connection tracking at
http://www.cs.princeton.edu/~jns/security/iptables/iptables_conntrack.html
Further on, the following examples of using firewall rules are given:
This can be done by putting rules in the input chain to match packets with the destination address of the router entering the router through all interfaces.
This can be done by putting rules in the forward chain to match packets passing through the router with the destination addresses of customer's network.
This can be done by enabling the masquerading action for source NAT rules.
This can be done by putting rules in the forward chain, or/and by masquerading (source NAT) only those connections, that are allowed.
Examples of setting up firewalls are discussed below.
Example of Firewall Filters
Assume we want to create a firewall, that
The IP addresses and routes of the MikroTik router are as follows:
[admin@MikroTik] > ip address print
# ADDRESS NETWORK BROADCAST INTERFACE
0 10.0.0.217/24 10.0.0.217 10.0.0.255 Public
1 192.168.0.254/24 192.168.0.0 192.168.0.255 Local
[admin@MikroTik] > ip route print
Flags: X - disabled, I - invalid, D - dynamic, J - rejected,
C - connect, S - static, R - rip, O - ospf, B - bgp
# DST-ADDRESS G GATEWAY DISTANCE INTERFACE
0 S 0.0.0.0/0 r 10.0.0.1 1 Public
1 DC 192.168.0.0/24 r 0.0.0.0 0 Local
2 DC 10.0.0.0/24 r 0.0.0.0 0 Public
[admin@MikroTik] >
[admin@MikroTik] > ip firewall rule input
[admin@MikroTik] ip firewall rule input> add protocol tcp tcp-option non-syn-only \
\... connection-state=established comment="Allow established TCP connections"
[admin@MikroTik] ip firewall rule input> add protocol udp comment="Allow UDP connections"
[admin@MikroTik] ip firewall rule input> add protocol icmp comment="Allow ICMP messages"
[admin@MikroTik] ip firewall rule input> add src-addr 10.5.8.0/24 \
\... comment="Allow access from 'trusted' network 10.5.8.0/24 of ours"
[admin@MikroTik] ip firewall rule input> add action reject log yes \
\... comment="Reject and log everything else"
0 ;;; Allow established TCP connections
dst-address=0.0.0.0/0:0-65535 out-interface=all protocol=tcp
icmp-options=any:any tcp-options=non-syn-only
connection-state=established flow="" src-mac-address=00:00:00:00:00:00
limit-count=0 limit-burst=0 limit-time=0s action=accept log=no
1 ;;; Allow UDP connections
dst-address=0.0.0.0/0:0-65535 out-interface=all protocol=udp
2 ;;; Allow ICMP messages
dst-address=0.0.0.0/0:0-65535 out-interface=all protocol=icmp
3 ;;; Allow access from 'trusted' network 10.5.8.0/24 of ours
src-address=10.5.8.0/24:0-65535 in-interface=all
dst-address=0.0.0.0/0:0-65535 out-interface=all protocol=all
4 ;;; Reject and log everything else
limit-time=0s action=reject log=yes
Thus, the input chain will accept the allowed connections and reject and log everything else.
To protect the customer's network, we should match all packets with destination address 192.168.0.0/24 that are passing through the router. This can be done in the forward chain. We can match the packets against the IP addresses in the forward chain, and then jump to another chain, say, 'customer'. We create the new chain and add rules to it:
[admin@MikroTik] ip firewall> add name=customer
# NAME POLICY
0 input accept
1 forward accept
2 output accept
3 router none
4 customer none
[admin@MikroTik] ip firewall> rule customer
[admin@MikroTik] ip firewall rule customer> add protocol tcp tcp-option non-syn-only \
[admin@MikroTik] ip firewall rule customer> add protocol udp \
\... comment="Allow UDP connections"
[admin@MikroTik] ip firewall rule customer> add protocol icmp \
\... comment="Allow ICMP messages"
[admin@MikroTik] ip firewall rule customer> add protocol tcp tcp-option syn-only \
\... dst-address 192.168.0.17/32:80 \
\... comment="Allow http connections to the server at 192.168.0.17"
[admin@MikroTik] ip firewall rule customer> add protocol tcp tcp-option syn \
\... dst-address 192.168.0.17/32:25 \
\... comment="Allow smtp connections to the server at 192.168.0.17"
\... src-port 20 dst-port 1024-65535 \
\... comment="Allow ftp data connections from servers on the Internet"
[admin@MikroTik] ip firewall rule customer> add action reject log yes \
[admin@MikroTik] ip firewall rule customer> print
3 ;;; Allow http connections to the server at 192.168.0.17
dst-address=192.168.0.17/32:80 out-interface=all protocol=tcp
icmp-options=any:any tcp-options=syn-only connection-state=any flow=""
4 ;;; Allow smtp connections to the server at 192.168.0.17
dst-address=192.168.0.17/32:25 out-interface=all protocol=tcp
5 ;;; Allow ftp data connections from servers on the Internet
src-address=0.0.0.0/0:20 in-interface=all
dst-address=0.0.0.0/0:1024-65535 out-interface=all protocol=tcp
6 ;;; Reject and log everything else
Note about the rule #5: active ftp data connections are made from the server's port 20 to the client's tcp port above 1024.
All we have to do now is to put rules in the forward chain, that match the IP addresses of the customer's hosts on the Local interface and jump to the customer chain:
[admin@MikroTik] ip firewall rule forward> add out-interface=Local action=jump \
\... jump-target=customer
[admin@MikroTik] ip firewall rule forward> print
dst-address=0.0.0.0/0:0-65535 out-interface=Local protocol=all
limit-time=0s action=jump jump-target=customer log=no
Thus, everything that passes the router and leaves the Local interface (destination of the customer's network) will be processed against the firewall rules of the customer chain.
[admin@MikroTik] ip firewall rule forward> add protocol icmp out-interface Public \
\... comment="Allow ICMP ping packets"
[admin@MikroTik] ip firewall rule forward> add src-address 192.168.0.17/32 out-interface \
\... Public comment="Allow outgoing connections form the server at 192.168.0.17"
[admin@MikroTik] ip firewall rule forward> add action reject out-interface Public log yes \
1 ;;; Allow ICMP ping packets
dst-address=0.0.0.0/0:0-65535 out-interface=Public protocol=icmp
2 ;;; Allow outgoing connections form the server at 192.168.0.17
src-address=192.168.0.17/32:0-65535 in-interface=all
dst-address=0.0.0.0/0:0-65535 out-interface=Public protocol=all
3 ;;; Reject and log everything else
Example of Source NAT (Masquerading)
If you want to 'hide' the private LAN 192.168.0.0/24
'behind' one address 10.0.0.217 given to you by the ISP
(see the network diagram in the Application Example above),
you should use the source network address translation (masquerading)
feature of the MikroTik router.
originated from the network 192.168.0.0/24 to the address 10.0.0.217 of the router
To use masquerading, a source NAT rule with action 'masquerade' should be added to the firewall configuration:
[admin@MikroTik] ip firewall src-nat> add action=masquerade out-interface=Public
0 src-address=0.0.0.0/0:0-65535 dst-address=0.0.0.0/0:0-65535
out-interface=Public protocol=all icmp-options=any:any flow=""
All outgoing connections from the network 192.168.0.0/24 will have source address 10.0.0.217 of the router and source port above 1024. No access from the Internet will be possible to the Local addresses. If you want to allow connections to the server on the local network, you should use Static Network Address Translation (NAT).
Example of Destination NAT
Assume you need to configure the MikroTik router for the following network setup,
where the server is located in the private network area:
The server's address is 192.168.0.4, and we are running web server on it that listens to the TCP port 80. We want to make it accessible from the Internet at address:port 10.0.0.217:80. This can be done by means of Static Network Address translation (NAT) at the MikroTik Router. The Public address:port 10.0.0.217:80 will be translated to the Local address:port 192.168.0.4:80. One destination NAT rule is required for translating the destination address and port:
[admin@MikroTik] ip firewall dst-nat> add action=nat protocol=tcp \
