RadioLAN 5.8GHz Wireless Interface
Document revision 22-Mar-2001
This document applies to the MikroTik RouterOS V2.4 and V2.5
Overview
The MikroTik RouterOS supports the following RadioLAN 5.8GHz
Wireless Adapter hardware:
- RadioLAN ISA card (Model 101).
For more information about the RadioLAN adapter hardware please see the relevant
User’s Guides and Technical Reference Manuals.
Contents of the Manual
The following topics are covered in this manual:
Wireless Adapter Hardware and Software Installation
Software Packages
The MikroTik Router should have the radiolan software package installed.
The software package file radiolan-2.x.x.npk can be downloaded from
MikroTik’s web page www.mikrotik.com.
To install the package, please upload the correct version file to the router and reboot.
Use BINARY mode ftp transfer.
After successful installation the package should be listed under the installed
software packages list, for example:
[MikroTik] system package> print
# NAME VERSION BUILD-TIME UNINSTALL
0 radiolan 2.4 sep/25/2001 05:08:05 no
1 pptp 2.4 sep/25/2001 05:06:44 no
2 ppp 2.4 sep/25/2001 05:06:35 no
3 pppoe 2.4 sep/25/2001 05:06:45 no
4 ssh 2.4 sep/25/2001 05:08:11 no
5 routing 2.4 sep/25/2001 05:06:07 no
6 snmp 2.4 sep/25/2001 05:06:09 no
7 system 2.4 sep/25/2001 05:05:48 no
Software License
The RadioLAN 5.8GHz wireless adapters require the RadioLAN 5.8GHz wireless feature license.
One license is for one installation of the MikroTik RouterOS, disregarding how many cards
are installed in one PC box.
The wireless feature is not included in the Free Demo or Basic Software License.
The RadioLAN 5.8GHz Wireless Feature cannot be obtained for the Free Demo License.
It can be obtained only together with the Basic Software License.
System Resource Usage
Before installing the wireless adapter, please check the availability of
free IRQ's and I/O base addresses:
[MikroTik] system resource> irq print
IRQ USED OWNER
1 yes keyboard
2 yes APIC
3 no
4 yes serial port
5 no
6 no
7 no
8 no
9 yes ether1
10 no
11 yes pc1
12 no
13 yes FPU
14 yes IDE 1
[MikroTik] system resource> io print
PORT-RANGE OWNER
20-3F APIC
40-5F timer
60-6F keyboard
80-8F DMA
A0-BF APIC
C0-DF DMA
F0-FF FPU
1F0-1F7 IDE 1
2F8-2FF serial port
3C0-3DF VGA
3F6-3F6 IDE 1
3F8-3FF serial port
EE00-EEFF ether1
EF40-EF7F pc1
FC00-FC07 IDE 1
FC08-FC0F IDE 2
FC10-FC7F [CS5530]
Installing the Wireless Adapter
The basic installation steps of the wireless adapter should be as follows:
- Check the system BIOS settings and make sure you do not have the
'PnP OS Installed' set to 'Yes'. If you have this setting, make sure it is set to 'No'.
- Check the system BIOS settings for peripheral devices,
like, Parallel or Serial communication ports. Disable them, if you plan to use IRQ's
assigned to them by the BIOS.
- Use the RLProg.exe to set the IRQ and Base Port address
of the RadioLAN ISA card (Model 101).
RLProg must be run from a DOS window. Use a separate computer or a bootable floppy]
to run the RLProg utility and set the hardware parameters. The factory default values
of I/O 0x300 and IRQ 10 might conflict with other devices.
Please note, that not all combinations of I/O base addresses and IRQ's may work
on your motherboard.
As it has been observed, the IRQ 5 and I/O 0x300 work in most cases.
Loading the Driver for the Wireless Adapter
The ISA card requires the driver to be loaded by issuing the following command:
[MikroTik] > driver add name=radiolan io=0x300
[MikroTik] > driver print
Flags: I - invalid, D - dynamic
# DRIVER IRQ IO MEMORY ISDN-PROTOCOL
0 D RealTek RTL8129/8139
1 ISA RadioLAN 0x300
[MikroTik] >
There can be several reasons for a failure to load the driver:
- The driver cannot be loaded because other device uses the requested IRQ.
Try to set different IRQ using the RadioLAN configuration utility.
- The requested I/O base address cannot be used on your motherboard.
Try to change the I/O base address using the RadioLAN configuration utility.
Wireless Interface Configuration
If the driver has been loaded successfully (no error messages), and you have the
required RadioLAN 5.8GHz Wireless Software License, then the RadioLAN 5.8GHz Wireless
interface should appear under the interfaces list with the name radiolanX, where X is 1,2,...
You can change the interface name to a more descriptive one using the 'set' command.
To enable the interface, use the 'enable' command:
[MikroTik] interface> print
Flags: X - disabled, D - dynamic
# NAME MTU TYPE
0 ether1 1500 ether
1 X radiolan1 1500 radiolan
[MikroTik] interface> enable radiolan1
# NAME MTU TYPE
0 ether1 1500 ether
1 radiolan1 1500 radiolan
More configuration and statistics parameters can be found under the '/interface radiolan' menu:
[MikroTik] interface> radiolan
[MikroTik] interface radiolan> print
0 name: radiolan1 mtu: 1500 mac-address: 00:A0:D4:20:42:EE distance: 0-150m
tx-diversity: disabled rx-diversity: disabled default-dst: firstclient
max-retries: 15 sid: bbbb card-name: 00A0D42042EE
cfg-destination: 00:00:00:00:00:00 arp: enabled
Argument description:
number - Interface number in the list
name - Interface name
mtu - Maximum Transmit Unit (68...1900 bytes). Default value is 1500 bytes.
mac-address - MAC address. Cannot be changed.
distance - distance setting for the link (0-10.2km)
rx-diversity - Receive diversity (disabled / enabled)
tx-diversity - Transmit diversity (disabled / enabled)
default-dst - deafault destination (alone / ap / cfg / firstap / firstclient).
It sets the destination where to send the packet if it is not for a clinet in the radio network.
max-retries - maximum retries before dropping the packet
sid - Service Set Identifier
card-name - Card name
cfg-destination - MAC address of a host in the radio network where to send the packet,
if it is for none of the radio clients.
arp - Address Resolution Protocol (disabled / enabled / proxy-arp)
You can monitor the status of the wireless interface:
[MikroTik] interface radiolan> monitor radiolan1
default: 00:00:00:00:00:00
valid: no
Here, the wireless interface card has not found any neighbour.
To set the wireless interface for working with another wireless card in a point-to-point link,
you should set the following parameters:
- The Service Set Identifier. It should match the sid of the other card.
- The Distance should be set to that of the link. For example, if you have 6km link,
use distance 4.7km-6.6km.
All other parameters can be left as default:
[MikroTik] interface radiolan> set 0 sid ba72 distance 4.7km-6.6km
distance: 4.7km-6.6km tx-diversity: disabled rx-diversity: disabled
default-dst: firstclient max-retries: 15 sid: ba72 card-name: 00A0D42042EE
[MikroTik] interface radiolan> monitor 0
default: 00:A0:D4:20:42:47
valid: yes
You can monitor the list of neighbours having the same sid and being within the radio range:
[MikroTik] interface radiolan> neighbours print radiolan1
NAME MAC-ADDRESS FLAGS ACCESS-POINT
00A0D4204247 00:A0:D4:20:42:47 D
You can test the link by pinging the neighbour by its MAC address:
[MikroTik] interface radiolan> ping radiolan1 \
mac-address 00:A0:D4:20:42:47 size 1500 count 50
Sent: 2/50 (4%), Ok: 2/2 (100%) max/avg/min retries: 0/0.0/0
Sent: 12/50 (24%), Ok: 12/12 (100%) max/avg/min retries: 0/0.0/0
Sent: 22/50 (44%), Ok: 22/22 (100%) max/avg/min retries: 0/0.0/0
Sent: 32/50 (64%), Ok: 32/32 (100%) max/avg/min retries: 0/0.0/0
Sent: 42/50 (84%), Ok: 42/42 (100%) max/avg/min retries: 0/0.0/0
Sent: 50/50 (100%), Ok: 50/50 (100%) max/avg/min retries: 0/0.0/0
Wireless Troubleshooting
- The radiolan interface does not show up under the interfaces list
Obtain the required license for RadioLAN 5.8GHz wireless feature.
- The wireless card does not obtain the MAC address of the default destination
Check the cabling and antenna alignment.
Wireless Network Applications
Two possible wireless network configurations are discussed in the following examples:
Point-to-Point Setup with Routing
Let us consider the following network setup with two MikroTik Routers
having RadioLAN interfaces:
- The Router#1 has IP address/netmask 10.1.1.12/24 on the Ethernet interface ether1,
and 10.1.0.1/30 on the RadioLAN interface radiolan1.
- The Router#2 has IP address/netmask 192.168.0.254/24 on the Ethernet interface ether1,
and 10.1.0.2/30 on the RadioLAN interface radiolan1.
The minimum configuration required for the RadioLAN interfaces of both routers is:
- Setting the Service Set Identifier (up to alphanumeric characters).
In our case we use ssid "ba72".
- Setting the distance parameter, in our case we have 6km link.
The IP addresses assigned to the wireless interface of Router#1 should be from the network 10.1.0.0/30, e.g.:
[MikroTik] ip address> add address 10.1.0.1/30 interface radiolan1
[MikroTik] ip address> print
# ADDRESS NETMASK NETWORK BROADCAST INTERFACE
0 10.1.0.1 255.255.255.252 10.1.0.1 10.1.0.3 radiolan1
1 10.1.1.12 255.255.255.0 10.1.1.12 10.1.1.255 ether1
The default route should be set to the gateway router 10.1.1.254.
A static route should be added for the network 192.168.0.0/24:
[MikroTik] ip route> add gateway 10.1.1.254 interface ether1
[MikroTik] ip route> add dst-address 192.168.0.0/24 gateway 10.1.0.2 \
interface radiolan1
[MikroTik] ip route> print
# DST-ADDRESS NETMASK GATEWAY PREF-ADDRESS INTE...
0 10.1.1.0 255.255.255.0 0.0.0.0 10.1.1.12 ether1 D K
1 10.1.0.0 255.255.255.252 0.0.0.0 10.1.0.1 radi... D K
2 192.168.0.0 255.255.255.0 10.1.0.2 0.0.0.0 radi...
3 0.0.0.0 0.0.0.0 10.1.1.254 0.0.0.0 ether1
The Router#2 should have addresses 10.1.0.2/30 and 192.168.0.254/24 assigned to the
radiolan and Ethernet interfaces respectively. The default route should be set to 10.1.0.1
Point-to-Point Setup with Bridging
The radiolan interface setup is similar to that in the previous example.
However, briding of the desired protocols should be enabled for the radiolan and ethernet interfaces:
[MikroTik] bridge> set ip forward arp forward other forward
[MikroTik] bridge> print
ip: forward
arp: forward
ipx: discard
appletalk: discard
ipv6: discard
other: forward
priority: 1
[MikroTik] bridge> interface
[MikroTik] bridge interface> print
# INTERFACE FORWARD
0 ether1 no
1 radiolan1 no
[MikroTik] bridge interface> set 0 forward yes
[MikroTik] bridge interface> set 1 forward yes
# INTERFACE FORWARD
0 ether1 yes
1 radiolan1 yes
Enable the bridge interface and assign the IP address to it, as well as set the default gateway:
# NAME TYPE MTU
0 ether1 ether 1500
1 radiolan1 radiolan 1500
( 2)bridge1 bridge 1500
[MikroTik] interface> enable 2
[MikroTik] interface> /ip address
[MikroTik] ip address> add address 10.1.1.12/24 interface bridge1
0 10.1.1.12 255.255.255.0 10.1.1.12 10.1.1.255 bridge1
[MikroTik] ip address> .. route add gateway 10.1.1.254 interface bridge1
[MikroTik] ip address> .. route print
0 10.1.1.0 255.255.255.0 0.0.0.0 10.1.1.12 bridge1 D K
1 0.0.0.0 0.0.0.0 10.1.1.254 0.0.0.0 bridge1
The Router#2 should be set similarly, a different IP address assignet to it, e.g.,
10.1.1.13/24, the default gateway is 10.1.1.254.
Thus, the Ethernet networks are bridged over the RadioLAN point-to-point link.
© Copyright 1999-2002, MikroTik
