Network setups with IPIP interfaces:
IPIP Setup IP over IP Interface management can be accessed under the /interface ipip submenu.
You can add an IPIP tunnel interface using the /interface ipip add command:
[MikroTik_1] interface ipip> add name test_IPIP mtu 1480 local-address 10.5.8.169 remote-address 10.5.8.171 [MikroTik_1] interface ipip> print Flags: X - disabled 0 X name: test_IPIP mtu=1480 local-address=10.5.8.169 remote-address=10.5.8.171 [MikroTik_1] interface ipip> enable 0 [MikroTik_1] interface ipip> print Flags: X - disabled 0 name: test_IPIP mtu=1480 local-address=10.5.8.169 remote-address=10.5.8.171 [MikroTik_1] interface ipip>
Descriptions of settings:
name - Interface name for reference
mtu - Maximum Transmit Unit. Should be set to 1480 bytes to avoid fragmentation of packets. May be set to 1500bytes if mtu path discovery is not working properly on links.
local-address - Local address on router which sends IPIP traffic to the remote side.
remote-address - The IP address of the other side of the IPIP tunnel - may be any RFC 2003 compliant router.
Use /ip address add command to assign an IP address to the IPIP interface.
There is no authentication or 'state' for this interface. The bandwidth usage of the interface may be monitored with the 'monitor' feature from the 'interface' menu.
The router at the other end should have the remote-address set to [MikroTik_1].
IPIP CISCO Example Our IPIP implementation has been tested with Cisco 1005. Sample of the Cisco 1005 configuration:
interface Tunnel0 ip address 10.3.0.1 255.255.255.0 tunnel source 10.5.8.179 tunnel destination 10.5.8.169 tunnel mode ipip
http://www.ietf.org/rfc/rfc1853.txt?number=1853
http://www.ietf.org/rfc/rfc2003.txt?number=2003
http://www.ietf.org/rfc/rfc1241.txt?number=1241
